Camera Phone Koni struts photos
^^ good info to know, I do autocross and do my suspension tuning in the canyons, so would like to be able to do it myself externally. I think I'll just save for a set of CA adjustable coilovers (complete with ride height adjustment) Out of curiousity though, how much do the konis cost? The sportline springs with OEM dampers I have on there now do okay and are pretty predictable, but I don't know if I can handle the rough ride around town much longer since it's my daily driver. would like to make it soft for daily use and hard for track/canyon use.
That's 900 installed he said. They are a bit less then that, you are going to have to factor in that it's going to cost a couple hundred for someone else to cut your factory struts to fit the Koni cartridges in and do the rears.
The rears you can also do yourself as far as adjusting goes. Just need to pop the back tires off and the shocks are held in by two bolts, un-do those then make adjustments, bolt back in put tires back on and your done.
