can't stop squeeking
Old Jul 8, 2010 | 09:13 AM
ecot3c inside's Avatar
okay so this started happening worse over the past two weeks. I put on my dropzone springs, yes shitty springs I know, but too late for that now just wanted it lowered. It squeeks like a ****. even if the car is off and I go to hop in it has a high pitched squeek, but only side to side, although while driving STRAIGHT it squeeks horrible, and is worse when the engine has been on longer through out the day.. I dont think the sway bar would cause squeeks, strut mounts would be with the turn of the steering wheel right?, am I missing something?? It sounds like a guy banging a chick on a Mr.squeeks mattress...
Old Jul 8, 2010 | 09:15 AM
umrdyldo's Avatar
I read this and all i can think of is Uncle Buck
Old Jul 9, 2010 | 01:38 AM
beatsfanatics's Avatar
damn
man i installed dropzone lowering springs as well and the front springs squeek like a bitch!! im so sick of it.. did you find an answer for yours??
Old Jul 9, 2010 | 08:18 AM
lol. no, the only answer I will probably get is "it's your fault for buying cheap ****". But w.e, I cut my bump stops and still slam really hard when I hit a bump.
Old Jul 10, 2010 | 02:36 AM
man im fine with the bumps for the most part but the squeeking is horrible... ill just sell them on craigslist or something lol
Old Jul 10, 2010 | 03:33 PM
hey i found the squeeking problem! you kno the vertical bar that connects to the strut?? well the strut arm was rubbing against the bult wrong... i took it off and put it back on and it took almost all of the squeeking out... im thinking about putting a washer inbetween it all to take it all out permanently
Old Jul 13, 2010 | 08:51 PM
the sway bar endlinks? Are you sure your car squeaks like mine??
Old Jul 14, 2010 | 01:20 AM
i thought i fixed it with that but it came back the next time i pulled the tire off... and then i tried spraying wd-40 on the nut at the top of the strut under the hood and i havent heard a single squeak since... its been about 3 days... good luck dude
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
Dirtybutwhole
Sep 26, 2015 06:53 PM
