Carbotech Street pads for TC
Old May 28, 2011 | 02:04 AM
ronn's Avatar
Bobcat:
Fronts:
2007+ Cheverolet Cobalt SS 2.0L Turbo Carbotech Bobcat Front Brake Pads
Carbotech™ Bobcat 1521™
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use
Old May 28, 2011 | 02:20 AM
Maven's Avatar
Im gonna say stock pads are still higher performance than those. I wouldnt put anything less than an AX6 on an LNF.
Old May 28, 2011 | 02:31 AM
ronn's Avatar
Well, I was thinking about a very good street application. AX6 is really an auto cross pad and much more aggressive..dusting and noise.
Maybe a better alternative to Hawk HPS that many are now using on the fronts?
Carbotech™ AX6™ (1106™)
The AX6™ takes the place of the Panther Plus™ compound that was so successful. AX6™ was specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range (50°F to 1150°F +). Advanced compound matrix provides an excellent initial “bite”, high coefficient of friction, and very progressive brake modulation and release characteristics. AX6™ offers high fade resistance, rotor friendliness at all temperatures, excellent cold stopping power, and non corrosive dust. As a result, AX6™ is an excellent choice for Autocross & AX6™ has gained tremendous popularity with SCCA Prosolo/Solo2 competitors for its fantastic bite, release & modulation. Many drivers use the AX6™ for street driving as well, even though Carbotech doesn’t recommend street driving with AX6™ due to possible elevated levels of dust and noise . AX6™ is NOT a race compound, and should not be used as such. AX6™ shouldn’t be used by any intermediate or advanced track day drivers, and should not be used with “R” compound tires (racing tires).
Old May 29, 2011 | 02:49 AM
Maven's Avatar
Yeah, i would rate the AX6 as a step above the Hawk HPS in performance, noise and dust(HPS being very quiet and very low dust), but still not as noisy/dusty as the HP+ Hawk HPS are also lower performance than stock Ferodo's in my opinion as well. Ill be running AX6's (LSJ pad style) this summer.
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Extremespeed
Sep 29, 2015 04:34 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
