check my alignment
Old Jun 23, 2010 | 03:07 AM
06cobalt racer's Avatar
check my alignment
rear axle--
camber -.30*/-.33*
toe +.17/+.10
front axle--
castor +4.11*/+5.00*
k.p.i. (kingpin inclination) +3.35*/+4.54*
toe out on turns +.24*/-2.32*
camber -.46/-.49
toe +.06/+.06
how do all the numbers look? is the front castor ok to be off by .89? the numbers are left/right
Old Jun 23, 2010 | 04:52 PM
LSChris's Avatar
It pulls, correct? Tell them to do it again, those numbers aren't good.
Old Jun 23, 2010 | 05:35 PM
yeah it pulls to the left. what should they change?
Last edited by 06cobalt racer; Jun 23, 2010 at 05:35 PM. Reason: Automerged Doublepost
Old Jun 24, 2010 | 08:44 AM
bump taking it back tomorrow.
Old Jun 24, 2010 | 08:49 AM
mmcgee123's Avatar
That caster is what's causing the pull which isn't adjustable how to ur control arm bustings and struts look
Old Jun 24, 2010 | 08:56 AM
onefstgtu's Avatar
Looks like you need a lower control arm..Did you hit a curb? Caster is causing your pull and its not adjustable.
Old Jun 24, 2010 | 09:58 AM
installed coilovers so struts are good. i have had the car and never hit a curb since march of 08. its never pulled before till after alignment.
Old Jun 24, 2010 | 05:27 PM
Old Jun 25, 2010 | 06:10 AM
bump take it in in 4 hours
2 hours
Last edited by 06cobalt racer; Jun 25, 2010 at 06:10 AM. Reason: Automerged Doublepost
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
yellow dragon
Sep 28, 2015 09:49 PM
