clunking in rear right of car when driving??
Old May 19, 2007 | 01:25 PM
cpraider12's Avatar
aite guys i put my sportlines on and also my koni rear struts and also my progress rear sway bar about 2weeks ago
i went to get my car aligned and all after a lil while i started hearing this clunking noise from my rear passenger side of the car i have no clue wut it could be ne body else have an idea??
it happens when im at low speeds and when i got over some bumps not all
thanks guys
-Jerzy
Old May 19, 2007 | 01:46 PM
RJSS's Avatar
I know nothing about suspensions but did you ever notice it before messing with the suspension? It could be the fuel system. It makes that tapping noise at low speeds and has no correlation with bumps. Most people notice it shortly after they turn the car on or off, or cruising at low speeds up to a stop light. If that's what it is it is completely normal. It will clunk two or three times in a row, almost like you've got a midget in your trunk. If that's not what it is, I'm not much help.
Old May 19, 2007 | 01:49 PM
CTORANGESC's Avatar
It could be a nunber of things, Something may be lose. Like the Sway bar links, maybe the bushings or you didnt tighten down the shock bolts. Like I said it could be many things
Old May 19, 2007 | 07:18 PM
xponential's Avatar
Hey, Ive heard that friggen tapping noise before. Ive had the dealer check my drums numerous times, but nothing.
Sorry, Im not trying to jack anyones thread. If this is not related please PM me with further info.
Old May 19, 2007 | 07:22 PM
YelloEye's Avatar
I did the sportline/koni swap too, only thing I didn't do was the sway bar. Like the other guy said check your shock bolts. Also might be your swaybar mounts or something along that line.
Old May 19, 2007 | 07:31 PM
alaskacobalt's Avatar
I had the same problem, with my last car... it's a small dead kitten.
Old May 20, 2007 | 12:09 PM
xponential's Avatar
Great, that explains the smell.
Old May 20, 2007 | 01:25 PM
pjk91's Avatar
check the top strut nut. it could be that, or the spring settling when going around turns, or the spring being lifted off its perch when going over bumps. like they said, a number of things.
Old May 20, 2007 | 01:28 PM
No... that would be poop finger. I have a nasty habit of sniffing my holes via my pointer finger. ;0
Old May 20, 2007 | 01:30 PM
djcasper_bpm's Avatar
i'm gonna go with, theres a midget in your trunk.. i mean i have sat here and thought about this for a while now. and thats all it could be.. i just hope its not the midget in a bikini.. thats a real problem and the dealer wont cover that... hehe...
i've heard that knock before.. only at low speeds on cold mornings. but after it warms up outside. nothing.. i have no clue what it is...
Old May 20, 2007 | 01:40 PM
You mean this guy?
Old May 20, 2007 | 06:28 PM
xponential's Avatar
The dealer better cover that.....damn
Old May 20, 2007 | 06:31 PM
RJSS's Avatar
I don't want to hijack this thread but what all of you guys, and maybe even cpraider12 are experiencing is the fuel system working normally. Check out this thread for more info: https://www.cobaltss.net/forums/problems-service-maintenance-69/bang-trunk-57577/
Also, here is the tech bulletin (i stole it from the thread):
Document ID# 1890375
2007 Chevrolet Cobalt
Subject: Noise from Rear Of Vehicle - keywords canister cold CVS click evap knock L61 LE5 noise rear solenoid tick vent #PIC4317B - (01/23/2007)
Models: 2006-2007 Saturn ION
2006-2007 Chevrolet Cobalt
2007 Pontiac G5
2005-2007 Pontiac Pursuit
with Engine RPO L61 or LE5
This PI is being superseded to update technical information. Please discard PIC4317A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A noise may be heard from the rear of vehicle; typically 3-5 knocks during initial cold start. The noise may sound like someone outside of the vehicle is tapping on the back window or on the rear exterior body panels.
Recommendation/Instructions:
This noise is from the vehicle's EVAP canister vent solenoid going through the diagnostic cleaning cycle, which is part of the software calibration set-up. Replacing the EVAP canister may not resolve the issue when the vehicle is re-exposed to a cold start. No parts should be replaced. This should be considered a normal condition for 2007 and previous model years.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old May 20, 2007 | 06:38 PM
thats him!!!!!
Old May 21, 2007 | 01:45 AM
DoubleClutchin_ION2's Avatar
omg maybe its your exhaust pipe... think about it, it runs over the rear arm....
Old May 21, 2007 | 01:56 AM
ehhh... I just took a look at it... which was tough, because first I had to ask my ricer friend what an exhaust was... and it looked like that would only be possible if it had a loose mount... it still has a pretty good amount of a distance, where I doubt it would come in contact with the arm.
I'm going to go with the midgets with hammers in the rear wheel well...
Old May 21, 2007 | 02:03 AM
neodude101's Avatar
I get that "tapping" too, although it never sounds like it's coming from outside to me. Definitely sounds like it's coming from somewhere inside/under the vehicle in the back. It's kind of cool to know that it's a self-checking mechanism and not just the springs settling or something like that.
I never get it on start-up or cruising around either. It's always probably 5-7 full seconds after I shut it off.
And mine doesn't sound like just three single taps. It sounds like two quick double-taps (where the first is a little lower pitch than the second) followed by a single tap (the lower pitched one again). Does that accurately describe anyone else's sound?
Old May 21, 2007 | 09:14 AM
xponential's Avatar
Exactly x2. - thats why I always thought it was a brake issue. But of course the never found anything.
Old Jun 7, 2007 | 02:02 AM
senior_brown's Avatar
maybe its hitting the bumpstop?
i think this started happening to me
dennis69
Oct 20, 2015 04:49 PM
63 Nova SS
Sep 12, 2015 11:21 PM
Sean Cummings
Sep 11, 2015 09:35 PM
ATOMbomb
Sep 11, 2015 10:48 AM
ROADKONE
Sep 9, 2015 02:32 PM
