Cobalt LCA bushing the same?
I'm pretty sure my lower control arm bushing are done in my LE5 LNF lower control arms but I just want to check that all the bushing in all models are the same? I found some solid rubber ones for pretty cheap that look to be better quality than the OEM ones but just want to be sure before I buy them.
I was going to mention the same thing lol
OP, Moog K201285 is listed for the fe3 suspension with zinc coating for aluminum control arms. They can be found for $30-40 a pop, sometimes a bit cheaper. While not anywhere near the quality of OTTP or Powell, it is a spherical joint and better than rubber replacements.
I might pick up the Moog spherical bushings sometime. I got the solid rubber ones a few years ago when my stockers were trashed. Haven't noticed any issues but wouldn't mind the upgrade.
It made a world of difference. I also did MOOG upper strut mounts, MOOG sway bar end links, and MOOG rear control arm bushings. I plan on doing MOOG front control arm bushings and MOOG rear trail beam bushings
Unbolt the bracket from the bushing, then pull the bushing off of the swaybar. Slip the new one on, easy peasy (I haven't done it, but it doesn't look hard). There should be a split in the bushing so you can slip it on without removing the swaybar.
Well from what I saw there are two bolts that hold the bushing to the subframe. One is easy, the other is tucked underneath the body almost so there wasn't an easy way to get to it. If you can show me how you do it, it would be much appreciated. I couldn't figure it out.
