Cobalt LCA bushing the same?
Old Sep 28, 2017 | 10:16 AM
SChassisMostly's Avatar
I'm pretty sure my lower control arm bushing are done in my LE5 LNF lower control arms but I just want to check that all the bushing in all models are the same? I found some solid rubber ones for pretty cheap that look to be better quality than the OEM ones but just want to be sure before I buy them.
Old Sep 28, 2017 | 10:40 AM
double clutch's Avatar
get some spherical bushings. youll never have to change them again.
Old Sep 28, 2017 | 11:04 AM
I looked at OTTP's but man they are a bit expensive.
Old Sep 28, 2017 | 11:07 AM
cw383's Avatar
I will have a set of Powells in the classifieds in the next few days.
Old Sep 28, 2017 | 11:30 AM
exninja's Avatar
95% sure this is accurate:
All aluminum LCA rear bushings are the same, but they are different than for the steel LCA's. So be sure it is specified for LE5.
Old Sep 28, 2017 | 11:50 AM
Moog makes some as well. Members have had success with them
Old Sep 28, 2017 | 11:55 AM
Tdubbs's Avatar
I was going to mention the same thing lol
OP, Moog K201285 is listed for the fe3 suspension with zinc coating for aluminum control arms. They can be found for $30-40 a pop, sometimes a bit cheaper. While not anywhere near the quality of OTTP or Powell, it is a spherical joint and better than rubber replacements.
Old Sep 28, 2017 | 12:24 PM
Hey thanks for this info guys. I appreciate it.
Old Sep 28, 2017 | 03:02 PM
I just purchased the Moog bushings with Moog sway bar endlinks. This should hopefully fix my clunk in the front suspension.
Old Sep 28, 2017 | 09:30 PM
63 Nova SS's Avatar
Good luck, I'm sure they will be better than stock. I run powells setup and it's been great.
Old Sep 29, 2017 | 11:38 AM
cobaltssdude420's Avatar
I got Powell’s installed the other day and they are great. I can pm you his price list if you like?
Old Sep 29, 2017 | 12:18 PM
That's okay. I got Moog ones yesterday but I appreciate the help!
Old Sep 29, 2017 | 12:22 PM
exninja's Avatar
I might pick up the Moog spherical bushings sometime. I got the solid rubber ones a few years ago when my stockers were trashed. Haven't noticed any issues but wouldn't mind the upgrade.
Old Sep 29, 2017 | 12:38 PM
royce777's Avatar
While your at replace your sway bar bushings
I can still give you the price list though lol. He’s got lots of goodies
Old Sep 29, 2017 | 12:39 PM
exninja's Avatar
Yeah actually I was thinking of replacing the LCA bushings when I replace the swaybar bushings since I need to do that.
Old Sep 29, 2017 | 12:41 PM
royce777's Avatar
It made a world of difference. I also did MOOG upper strut mounts, MOOG sway bar end links, and MOOG rear control arm bushings. I plan on doing MOOG front control arm bushings and MOOG rear trail beam bushings
Old Sep 29, 2017 | 12:43 PM
Yes that would be cool. His website doesn't have a lot of info.
Old Sep 29, 2017 | 12:44 PM
I bought replacement sway bar bushings but they look impossible in my LNF sedan. How are you supposed to do them without dropping the subframe??
Old Sep 29, 2017 | 01:07 PM
exninja's Avatar
Unbolt the bracket from the bushing, then pull the bushing off of the swaybar. Slip the new one on, easy peasy (I haven't done it, but it doesn't look hard). There should be a split in the bushing so you can slip it on without removing the swaybar.
Old Sep 29, 2017 | 01:13 PM
Well from what I saw there are two bolts that hold the bushing to the subframe. One is easy, the other is tucked underneath the body almost so there wasn't an easy way to get to it. If you can show me how you do it, it would be much appreciated. I couldn't figure it out.
Old Sep 29, 2017 | 01:18 PM
exninja's Avatar
The picture I saw showed a hole in the subframe where you can access it. I'm actually pretty upset with myself that I didn't do this when I replaced the engine.
Old Sep 29, 2017 | 01:54 PM
royce777's Avatar
I've done sway bar bushings on 3 diff LNFs. Easy just takes some patients.
Old Sep 29, 2017 | 01:56 PM
How did you do them?
Old Sep 29, 2017 | 02:01 PM
royce777's Avatar
there is a access hole in the sub frame for the one bolt and the other one you can get to from the top. use a small quarter inch ratchet and a extension.
