coilover question regarding LNF axles
Old Jul 23, 2012 | 11:44 AM
mattdracing's Avatar
i have a set of KW V 2 coilovers for my 08 tc balt. i am wanting to put them on soon but i want to make sure anybody hasnt had any problems after installing them. i know i will need an alignment im sure but has anybody heard of them snapping an axle after lowering? my friend snapped an axle on his LNF but im not sure if it was related to the fact that he had it lowered all the way on his coilovers (he was also on KW coilovers). thanks in advance!
Matt
Old Jul 23, 2012 | 11:51 AM
dakotaspeir's Avatar
#cobalthoes
Axle bind is a part of life
Old Jul 23, 2012 | 11:53 AM
Wangspeed's Avatar
LNF axles are massive. The only way you will break them is if you are a bonehead and slam the car, causing axle bind.
Old Jul 23, 2012 | 12:00 PM
ok cool...so if i just lower it to an amount that takes out most of the wheel gap that should be fine correct? because he had his car as low as it would possibly go on the coilovers
Old Jul 23, 2012 | 12:02 PM
ei3dag3's Avatar
would be good idea to get rotated mounts from powell and rack spacers. thats what im gonna do.
Old Jul 23, 2012 | 12:27 PM
could you send me a link for that? and will that help prevent axle bind? please forgive me for knowing nearly nothing as far as suspension goes haha
Old Jul 23, 2012 | 12:45 PM
ei3dag3's Avatar
no worries.
powell doesn't have any actual links for their site, but they make top notch parts for our platform.
OTTP Rotated Trans Mounts
here is a link to what they look like etc.
DO NOT buy from them.
Powell used to make their mounts and they ended up breaking there deal. Now OTTP continues to steal his design with shittier product.
Contact gloria directly at gloria@powellraceshop.com. shes is a major sweetheart and will work with you to answer any questions.
john powell may also chime in here, but he's pretty busy sometimes.
there are also several other threads arounds explaining it.
he also sells the spacers so you don't have steering
Steering Rack Spacers
heres a link to more info and what they look like.
same deal as above though. contact powell isntead.
Old Jul 24, 2012 | 07:53 AM
ok cool thanks! so if i order those 2 parts above it will get rid of my chances of axle bind for the most part regardless of how low i go?
Old Jul 27, 2012 | 07:42 PM
Shogokuma's Avatar
im lowered on CM springs and i get axle bind just to give you an idea an i just ordered powell rotated mounts ill let you know if it got rid of my axle bind
Old Jul 27, 2012 | 07:51 PM
BPacak's Avatar
Vtec Rep
Axle bind on cm springs? Haha
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
