nice you need prices for everything
I rearanged them most expensive to cheapest too. |
so whats different about them all? im new to coilovers
pretty much the more expensive they get the more adjustable they are.
IMHO the H&R coilovers are the best buy. very high quality product right there |
well i just bought the KW coilovers (variant 1) so when i get them in i'll let everyone know how they are. I had to do something my struts where totally shoot and i just had to replace one of my tires because of it.
im waiting and anticipating
I like the Cobalt Addiction Coilovers. They are the best price and the quality looks great. Anyone have those installed? Maybe Badg1rl?
I've got the J-body Performance Coil overs, and absolutely love them.
here's some info on the redesign, which hasn't been updated on his site yet: Basically uses Bilstein progressive dampener (special valving in the dampener adjusts stiffness automatically as you drive) adjustable height adjustable caster and camber |
no prob, just so you know, of the coil overs above, the only ones actually available are the JBP and the KW.
I think the KW variant 2 is a good set with enough flexibility to make it a good set of coil overs. the JBP are more of an ultra high quality coil over, (max performance & comfort) which is why it's pricey. as for the C.A. coils overs, I don't know. that pic seems to be just a generic picture, because I just don't see how those would fit the rear. I've asked several questions about them on other threads, I still have yet to receive any answers. oh well. |
My friend has a Set Of Variant 2 KW Coil Overs on his Focus and they are amazing, BTW I just installed the SS S/C Suspension on my LT what a world of Difference and it only took about two hours total. The front there are three bolts on the strut and three on the strut tower, then the whole thing comes out. The back one bolt and then you wiggle the spring out, the One more bolt and the shock comes off. Easiest Suspension I have ever worked with.
More Options These are on the way
http://www.tokicogasshocks.com/products/dspec/ |
the cobalt addiction coilovers look extremly similar to a B+G RS2 coilovers as they offer a 32way adjustable setup. they havnt updated the site w/ the cobalt buti believe its available. if the cobalt addiction are infact made by B+G, that is what i would get no doubt about it. i would go w/ the H&R or cobalt addiction (if they are made by B+G), if theyre not then i'd go w/ KW.
B+G are my number 1 choice. |
Originally Posted by victory_red_SS
So Ed, do you have the redesigned ones now? Mev is supposed to have a set ready for me when the engine comes home.
Someone on Here has a set of Koni Adjustables installed on his 2.4
I found him look at the last Pic https://www.cobaltss.net/forums//showthread.php?t=28573 |
Originally Posted by CTCOBALTSSS
I'm new to them too. I guess we just have to go to each link and read up on them.
Not sure if this helps anyone. From the Koni website.
Q: I want to lower my car with a coil-over sleeve kit. How do I setup my vehicle with KONIs and coil-over sleeves? A: There are many coil-over sleeve systems on the market but the key is to get ones that will fit the KONI damper properly. Most of these are built to fit over a large number of aftermarket shock absorber brands but this means many will not really fit well. KONI is unique in that some applications feature an adjustable spring seat mounted on a circlip on the shock body. This circlip design is extremely strong when it is loaded properly and the circlip is captured so that it cannot be forced open. However if the mounting on the circlip is unevenly loaded or not properly captured allowing the circlip to increase in diameter from load or impact, you have a potentially dangerous situation where damage could occur. With proper installation and loading, the circlip system allows for great strength and ride height adjustability at the same time. Additionally, when selecting and installing your coil-over system, care should be taken to avoid allowing the springs to coil bind (compressing the spring down to a solid state) during usage as this can risk bottoming and damage. A proper length bump rubber should be used to keep the spring from coil binding and the shocks from bottoming internally. You should contact the dealer or the manufacture of the coil-over system and get any necessary adapter rings necessary to mount the sleeve system to the KONI. |
Just to give you guys a bit of helpful information...you should know that MOST of these coilovers are designed for "race only" applications, therefore meaning they won't take well to pot holes, uneven roads, etc. Coilovers that are $1500+ are generally considered race only and are extremely uncomfortable UNLESS the company specifically says they are designed for street & track use. Be careful buying these things, you don't always need the most adjustable coilovers to get the best possible street setup. In many cases, you won't even use most of the assets in the system's design on the street. Tokico has already proven themselves time and time again with other imports and domestics as well. They generally have a good feel, and coupled with Eibach's springs could lead to a terrific setup for curvy roads. Plus, these are struts I believe, which are much more comfortable and cheaper too.
Koni is also a VERY good company to deal with when it comes to suspension. |
I've had KONI's on my sunfire for 80,000 miles on GroundControl sleeve coilovers, and the ride was awesome.
I'm really looking forward to the Tokico's if it really comes with that upper mount! |
