Coilovers
they have had enough. i have had them for like 2 years and they are riding really rough now. and springs are making noise. they have had probably around 70,000 miles on them. just time for new ones.
the tein's should be out soon. i'm waiting for those. worth it IMO
do you have any pics of your car slammed?
http://www.gravanatuning.com/261/1/1...e_2.4_FWD.html
Theres the link u can compare them to your other options see which one is best for you; if ur looking for performance and lowering gravana's set up did it for me; and my car is 2 inch's off the ground
Chad
I went with KWv2's for a reason. Reputation and reliability in a real race environment. The KWv2's rear dampers are Koni Yellows, just shorter to accommodate the drop. I would have gone with Bilstien, but too much for me at the time and not adjustable which is important to me for I see DD, Autox and open track.
Konis also cannot be adjusted without atleast unbolting one side from the car.
What I would like to see is one of these groups come out with a product that has easier adjustability in the rear. Jacking up the car should be plenty, shouldn't have to unbolt anything. If there was a knob that could be placed on the rear shocks, where a simple turn could adjust stiffness...that would be great. Also having the sleeves on the top of the springs, so that you don't have to remove the spring and sleeve to adjust ride height.
And for the fronts provide a form of adjustability other than by the spring perch for the ride height.
These are things I would look for in a coilover setup.
Oh and one last thing, which is just being picky but also allowing the ability to run larger swaybar endlinks on the fronts or be provided with a set with the coilovers. I had to bore out the bolt holes on my KW's to run bwoody endlinks. Even though the coilovers were intended for stock endlinks, you really don't want to take a drill to $1300 coilovers.
I don't know if they are different for Cobalts but I think the KW's are a bit outdated in terms of their features. I run them on my Ion and you can only adjust ride height by playing with the spring perch. This is a big issue for ride quality and I wish I was aware of this at the time of my purchase.
Does anyone know why coilovers were designed in the first place? No, it was not so you could slam it to the ground.
You know, it's funny when you look at some of these less expensive, but high feature coilovers and you find over 200 hundred applications, but only 2 part #'s for replacement struts!
What is the single most important component to a suspension system? It's the damper. It does all the work =controls the movement and behavior of the wheels to the road surface. The damper is what makes the car handle in a safe and predictable manor. What the damper is doing is something you do not see, or able to measure unless placed it on a dyno for dampers, aka Shock Dyno. This is where the cheap coilovers fail and bad. Ask Ksport or any of the others for independent dyno test of their product and see if you get blown off like many others that have asked.
search ;DGs Autocross Secrets aka Autocross to win;
This is a very informative read. This was posted by allycat sometime ago. Read and you may learn.
Next, google, ksport problems, and read. Then google, kw suspension problems, see the difference.
no i didnt get the springs, car was officially totaled
As far as adjustability being outdated in their features, lets see; Moton, Koni, Bilstien, Ohlins, nor Penske suspensions use adjustable housings like ;example Ksport. They're not needed. Less is more in this case. Even Tein go this right. Aluminum housings, only the Asian coilovers are using this to my knowledge. Aluminum doesn't take impacts very well, possible fracuring. The more adjustments the more to go wrong at the worst time. Rear adjustment, dampers how often do you need to adjust them? An external knob, one more thing to break off from road debri. If the suspension is properly designed for the vehicle, the ride hieght will be dictated.
Also in regards to the knob on the rear shocks...how exactly would it break? I can't think of anything I plan on runing over that is going to put an adjustment knob at risk.
KW coilovers are nice yes, but IMO they are about $300 overpriced for what you get. From what I have seen so far, BC coilovers seem to have the most complete setup offered for the Cobalt and for a decent price.
http://www.modernperformance.com/pro...oducts_id=1601
