From Coils Back To Struts/Shocks Question
To save my lower back from any more abuse from DTW roads, I'm highly considering the move back to a strut/shock and spring setup for suspension from my Megan coils.
Going with the FE5 pack - Cobalt FE5 Struts and Shock Pkg FE5-S
And YYZ v2 - Powell YYZ V2 Spring Pkg YYZ V.2
I was wondering if I needed any more parts to complete the move?
TIA,
Mark
TIA,
Mark
Okay, sweet. So I don't need to buy anything else off this list? - http://www.crateenginedepot.com/2008...-W236C948.aspx
It was making me nervous, as I don't have any stock parts from when I swapped to coils.
This is just a DD. Koni's are overkill for me.
Thank you! Just gonna quote it here, so it doesn't get lost.
If you did not keep them, you will need a top strut mount with bearing, a top spring hat and rubber isolator, and a lower spring isolator. CED have the parts, you may have to beat on Tom a bit as his strut mounts and bearings are a little more money than you can get from Moog or whoever, but you cant get the isolators and spring hats anywhere else.
At the rear, the upper bump stop and the lower isolator are required, you may still have them, it depends what you tossed when you Megan ized your car.
One thing I can say: you will fall in love with the ride and handling all over again when you are done, and someone will buy your megans willingly. Good luck!
Metric
English
Frame to Chassis Bolts ( trailing cab)
100 N•m + 180°
74 lb ft +180°
OR 145 ft lbs no angle torque required
Stabilizer Link to Strut Nut
65 N•m
48 lb ft
Stabilizer Shaft Link to Stabilizer Bar Nut
80 N•m
59 lb ft
Strut Assembly to Steering Knuckle Nut
120 N•m
89 lb ft
Strut to Body Nut
20 N•m
15 lb ft
Strut Shaft Nut
70 N•m
52 lb ft
strut mount :
CED Upper Strut Mount Kit CED905907 $64.29 includes bearing and hardware. two required
Strut nut 22716359 (comes with FE5 struts if purchasing struts)
22716359 Nut, Frt Suspension Strut. M14x2x25 with nylon insert 7.91 two required
Strut Insulator, Frt Spring Upper (90MM ID) 22716382
22716382 Strut Insulator, Frt Spring Upper (90MM ID) 1 required per side $6.05 two required
Use with 22716379
Cobalt TC FE5 Front Spring Seat 22716379 $7.56 two required
22716379 Front Spring Seat
use with 22716382 Insulator
Shield 21992520
two required, Front Suspension Strut
$7.59
Insulator 22716383
Insulator Front Spring Lower
two required, $ 10.84
Celasto strut Bumper 22716381
22716381 Bumper, Front Suspension Strut
$7.91 two required.
English
100 N•m + 180°
74 lb ft +180°
65 N•m
48 lb ft
80 N•m
59 lb ft
120 N•m
89 lb ft
Strut to Body Nut
20 N•m
15 lb ft
Strut Shaft Nut
70 N•m
52 lb ft
strut mount :
Use with 22716379
Shield 21992520
$7.59
Insulator 22716383
$7.91 two required.
Thank you John! I owe you a beer.
I take it that I should just buy 2 of everything you listed and I'll be set.
I noticed that all the part numbers you listed are for the front, but you stated that the rear would need upper bump stop and insulators. Am I just daft and those are already listed? Note: I have nothing left over from coil conversion.
Crav3, look out for my FS thread.
Cobalt Rear Spring Mount 04-10 25993736
25993736 Cobalt Rear Spring upper Bumper assembly fits 04 - 10
Replaces 22734495
$42 12 this is expensive and you need two!
The lower rear is not listed anywhere, thats a Monday job. 800 441 5150
Not up yet, as they're still on my car and I'm trying to figure this out.
Ah, okay. Thanks!
Noted, thank you.
I did not list the rear parts. I will look for those for you - two pieces per side upper which isolates and has a bump stop and lower which centers and isolates.
Replaces 22734495
Replaces 22734495
Noted, thank you.
