From Coils Back To Struts/Shocks Question
Old Dec 14, 2012 | 08:48 AM
Gelladuga69's Avatar
To save my lower back from any more abuse from DTW roads, I'm highly considering the move back to a strut/shock and spring setup for suspension from my Megan coils.
Going with the FE5 pack - Cobalt FE5 Struts and Shock Pkg FE5-S
And YYZ v2 - Powell YYZ V2 Spring Pkg YYZ V.2
I was wondering if I needed any more parts to complete the move?
TIA,
Mark
Old Dec 14, 2012 | 12:19 PM
Wangspeed's Avatar
Nope. Konis are even better, but if you ditched your stock setup, then you'll have to get donors.
Old Dec 14, 2012 | 01:29 PM
Okay, sweet. So I don't need to buy anything else off this list? - http://www.crateenginedepot.com/2008...-W236C948.aspx
It was making me nervous, as I don't have any stock parts from when I swapped to coils.
This is just a DD. Koni's are overkill for me.
Old Dec 14, 2012 | 01:48 PM
BLKLS's Avatar
I think you may have to get the strut tops and bearings and stuff. Ask them when you call. It looks like thath is just the shocks.
Old Dec 14, 2012 | 01:52 PM
Bleh.
Hopefully John or Tom sees this thread and can chime in. I'm at a loss.
Old Dec 14, 2012 | 06:34 PM
Powell Race Parts's Avatar
chimed in on the other thread.
Old Dec 15, 2012 | 02:40 PM
r1owner's Avatar
So, YYZ V.2... Is this going to be the preferred spring for track cars or is it still the original?
Old Dec 15, 2012 | 02:58 PM
i would track v.1 but v.2 will be okay ;I like more rake for a fwd track car than v.2 provides
Old Dec 15, 2012 | 06:30 PM
Thank you! Just gonna quote it here, so it doesn't get lost.
If you did not keep them, you will need a top strut mount with bearing, a top spring hat and rubber isolator, and a lower spring isolator. CED have the parts, you may have to beat on Tom a bit as his strut mounts and bearings are a little more money than you can get from Moog or whoever, but you cant get the isolators and spring hats anywhere else.
At the rear, the upper bump stop and the lower isolator are required, you may still have them, it depends what you tossed when you Megan ized your car.
One thing I can say: you will fall in love with the ride and handling all over again when you are done, and someone will buy your megans willingly. Good luck!
Old Dec 15, 2012 | 07:45 PM
Metric
English
Frame to Chassis Bolts ( trailing cab)
100 N•m + 180°
74 lb ft +180°
OR 145 ft lbs no angle torque required
Stabilizer Link to Strut Nut
65 N•m
48 lb ft
Stabilizer Shaft Link to Stabilizer Bar Nut
80 N•m
59 lb ft
Strut Assembly to Steering Knuckle Nut
120 N•m
89 lb ft
Strut to Body Nut
20 N•m
15 lb ft
Strut Shaft Nut
70 N•m
52 lb ft
strut mount :
CED Upper Strut Mount Kit CED905907 $64.29 includes bearing and hardware. two required
Strut nut 22716359 (comes with FE5 struts if purchasing struts)
22716359 Nut, Frt Suspension Strut. M14x2x25 with nylon insert 7.91 two required
Strut Insulator, Frt Spring Upper (90MM ID) 22716382
22716382 Strut Insulator, Frt Spring Upper (90MM ID) 1 required per side $6.05 two required
Use with 22716379
Cobalt TC FE5 Front Spring Seat 22716379 $7.56 two required
22716379 Front Spring Seat
use with 22716382 Insulator
Shield 21992520
two required, Front Suspension Strut
$7.59
Insulator 22716383
Insulator Front Spring Lower
two required, $ 10.84
Celasto strut Bumper 22716381
22716381 Bumper, Front Suspension Strut
$7.91 two required.
Old Dec 15, 2012 | 11:20 PM
Crav3's Avatar
You gonna sell you're coilovers? How much lol i want
Old Dec 16, 2012 | 02:43 AM
Thank you John! I owe you a beer.
I take it that I should just buy 2 of everything you listed and I'll be set.
I noticed that all the part numbers you listed are for the front, but you stated that the rear would need upper bump stop and insulators. Am I just daft and those are already listed? Note: I have nothing left over from coil conversion.
Crav3, look out for my FS thread.
Old Dec 16, 2012 | 07:43 AM
I did not list the rear parts. I will look for those for you - two pieces per side upper which isolates and has a bump stop and lower which centers and isolates.
Cobalt Rear Spring Mount 04-10 25993736
25993736 Cobalt Rear Spring upper Bumper assembly fits 04 - 10
Replaces 22734495
$42 12 this is expensive and you need two!
The lower rear is not listed anywhere, thats a Monday job. 800 441 5150
Old Dec 16, 2012 | 09:12 AM
Crav3's Avatar
I couldn't find it -_-
Old Dec 16, 2012 | 10:07 AM
drumrush's Avatar
Rockauto.com is the best place to buy the top mounts for the struts, very cheap
Old Dec 16, 2012 | 12:22 PM
Not up yet, as they're still on my car and I'm trying to figure this out.
Replaces 22734495
Ah, okay. Thanks!
Noted, thank you.
Old Dec 17, 2012 | 02:15 AM
Crav3's Avatar
Haha alright but I wanna be first in line lol pm me how much you would want For them
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
