Cold weather and suspension noise
Hey everyone,
Whenever the outside temperature is below 0 Celcius (32 Fahrenheit for those in the States) my car squeaks whenever I go over speed bumps or drive on a slightly bumpy road.
Anyone else have this problem?
well I do know that if you brought your car in an complained about it they can "fix" it but you will suffer in handling performance.. I believe they replace the sway bar bushings.
Yeah, it's a 2009 SS. The dealership replaced some front bushings last year but the problem persists.
I have the 2009 SS sedan. so I do get the noise. every day going to work. OH the worst is when the shifter is frozen in first gear!!! I can move it back and forth but not side to side. It takes the car 15 mins of running to warm it up enough to move.
GettingAUsernameSucks mentioned it's a result of the TC having stiffer bushings than the 2.2/2.4 models (and it's actually the rear ones if you listen closely
). Naturally the colder the bushing gets, the more noise it's going to make. If you go to the dealership and complain they will replace them with a softer bushing but after the **** I put up with in my 2.2 I wouldn't recommend this.
sorry, I was joking, its the bushing on the swaybar/ sway bar endlinks. its actually a strange squeek that sounds like your bumper is scraping, lol.
Thanks for all of your help guys...glad to hear I'm not the only out there with this problem. GM really should get their act together and start producing some quality stuff. I've always considered myself a GM guy but I'm on my second Cobalt and I'm still disappointed.
Maybe I should buy a Ford next time?! lol
I figured you were being sarcastic but I'm kinda' new here and didn't want to disagree. lol.
If you are disappointed in your Cobalt TC I am sad for you, bang for $ its hard to beat. EVERYTHING else new that has performance even close to the TC is a lot more money...good luck in your quest for perfection...
The control arm bushings I make fix this you can buy them from OTTP a preffered vendor here. Another source of that squeaking noise are the swaybar drop links, the best fix for that are Powergrid Inc.com , drop links, you can buy those from OTTP as well or contact Chip directly at Powergrid. Eitherway you will be happy imho...
I agree; this car is great in the "bang for the buck" category but having said that, some criticism of GM in terms of build quality is still warranted. I've only ever owned GM vehicles (and will continue to do so) but I just wish quality control was a bit more stringent. While this might not be a deterrent for myself and most of us on this forum, I'd hate to see GM continue to lose market share to the European and Asian manufacturers as a result of poor quality control. I never ever thought I'd see the day that someone would consider buying a Hyundai over a GM. Hyundai Pony anyone??!! lol
Pretty much determined mine is the bushings where the front anti roll bar pivots on the chassis - the bushings get cold and stiff so instead of flexing, they kind of chatter when the front bar pivots as the bushing grabs/releases/grabs/etc on the bar.
Annoying as hell, got a few ideas for a fix but it's too damn cold in the garage, and by the time it's warm enough to work in, the squeeking is gone so I don't think about it - until it's too cold again
Ahhhhh, the joys of cost driven design......
Not to bring to life a dead post, but I'm glad I found this info. I work at a Chevy dealer and no one knew about this when I described it. I thought I was rubbing a splash shield but nothing's the matter when I get underneath. Mine is like clockwork- 32degrees and squeeking like mad, 33 and all is well. I have 7800 miles on my 09 SS/TC and for the first 7000 no noises and it was freakin cold. Why would it come out of nowhere?
DANRICKARD
Oct 1, 2015 12:08 AM
