combating wheel hop
combating wheel hop
You S/C guys are not the only ones to suffer from wheel hop. My car feels the effects too. Perhaps a solution could help me launch the car, getting a better 60ft time and lower my ET.
Please only post if you have used an aftermarket part
Tell me what it is, how much and your opinion.
thanks
thanks
Originally Posted by Cobalt_Supercharged
From the other posts I have read the J-Body Performance Control Arm Bushings are your best bet, but I don't know if they have them for the 2.4s yet. Might be something to look into.
OK IM going to give you the best singal part. Well sort singal.
Wheels and tires!
I had mad wheel hop befor I put the new wheels and tires on my car.
Now I have almost non at all.
The only other mod I have that is helping wheel hop is the ZZP motor mount.
About 95% of my wheel hop is gone.
Ill be doing the control arm bushings soon and hop to have 100% of it gone after that.
Later
Wheels and tires!
Later
Wheels and tires!
Later
Wheels and tires!
Later
thats a pricey single part though
one of my friends has a torque brace from weapon-r and says most of his wheel hop is gone...its about $150 or so and you can install it yourself...i will be buying one really soon...tires would be good also but are expensive, something like pirelli p-zero nero M+S,i also know someone who has those and says it helps a lot but plan on spending upwards of $600 for a set unless you only did the front(their is hardly a noticable difference in looks from stock)...
Wheels and tires!
Later
Wheels and tires!
Later
Wheels and tires!
Later
Wheels and tires!
Later
On a more related note your best bet is an upper torque mount and transmission mount.
Originally Posted by Mercury
We need traction bars! I took a ride in Twincharged's Ion Redline w/ 280whp and his own custom traction bars and there was no wheel hop whatsoever.
Originally Posted by Roadrunner
what was the difference between the wheels and tires you got and the ones that you had stock?
My new rims are 20lb each and my new tires are 235-40-18s.
Later
Originally Posted by StreetDreamz
That's because the tires you have now don't stick as well as the factory ones. Plain and simple.
I can lounch at 2250Rpm now with almost no tire spin and almost no wheel hop. 1500Rpm was the max I could do with the stockers with out mad wheel hop and tire spin.
It will pull out of the hole alot faster then befor.
I have alot more traction that is why I have less wheel hop.
Its real simlpe realy. The tires have alot more traction so they dont brake lose so easy now and that translats to less wheel hop.
The lighter rims and tires help also in that there is less unsprung mass for the suspension to try to control. This makes the suspension more efective in controling wheel hop also.
Ill be doing the control arm bushings as soon as prothain releses there kit for the car in a bout 2 months.
Later.
Originally Posted by Doc
I hope you mean upper control arm bushings...
I think he ment the touqre brace that gose on top of the stock motor mount.
Later
Umm the Cobalt only has a lower control arm man.
Later
Later
who knows
he said upper I said upper...
he'll have to answer. I would just call them control arm bushings for now....if he thinks the torque braces that go on top of the motor mount will work, I would have to disagree....but, he'll clarify later when he reads this.
I second that the torque braces are not worth it. Just got to look at the motor being revved the other day with the one motor mount and front transmission mount and that sucker doesn't move at all.
