Control arms...cabs...questoins
Old Aug 31, 2009 | 11:58 PM
SlowBalt_06's Avatar
well i'm trying like hell to figure out what is causing this viberation i'm having between 35 and 43 mph....i've had 3 sets of wheels all balanced...alignments have checked out fine...wheel bearings are fine...i was gonna replace my axles thinking it was the axles hubs but what are the chances a bad control arm or cabs are causing this....
anyone running the intense cabs....?
Last edited by SlowBalt_06; Sep 1, 2009 at 12:15 AM. Reason: Automerged Doublepost
Old Sep 1, 2009 | 12:00 AM
BLKLS's Avatar
i've seen axles cause vibrations. control arm bushings , sure. get the front end up off the ground and shake the wheel.
Old Sep 1, 2009 | 12:15 AM
i did it really doesnt move
at all
Old Sep 2, 2009 | 12:04 AM
Maven's Avatar
Does the wheel move left to right?
Do you have the little metal retainers on the rotors and have aftermarket wheels?
Is your car auto or stick? Is it solely speed related or do you have to be in a certain gear at that speed?
Old Sep 2, 2009 | 12:09 AM
Manual ss.sc any gear yes aftermarket rims but happened with stockers too
Old Sep 7, 2009 | 08:52 PM
BLKLS's Avatar
ok so its not wheels, if the wheel move at all when its off the ground side to side, up and down, diagonal, front to back, somethings wrong. you would be able to feel movement in the wheel if the control arm bushing was shot.
is vibration felt more in the seat or in the steering wheel?
are you lowered?
Old Sep 7, 2009 | 10:03 PM
tru2nrtt777's Avatar
Also if the wheel "jiggled" side to side and up and down then it could be wheel bearing.
Old Sep 8, 2009 | 10:39 AM
tonio5555's Avatar
off topic: What are those little metal retainers on the rotors? When I did my brakes I wasn't sure what they were but I reused them just to be safe.
Old Sep 8, 2009 | 10:49 AM
Rangerondubz's Avatar
Just to hold the rotor on there during caliper mounting(in the factory)
You can break them off and toss em
Old Sep 9, 2009 | 08:26 PM
LivinModified's Avatar
how do you pop the ball joint off the control arm? do i just have to pull hard?
Old Sep 10, 2009 | 08:57 PM
qwikredline's Avatar
take cross bolt out and lift knuckle drop arm. It is not a taper fit it should be easy. Insert a lever in the split of the knuckle if it is very tight. To replace re insert the ball joint to knuckle and torque cross bolt to 37 ft lbs, then back off 3/4 turn then re-torque to 37 ft lbas + 30 degrees.
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
Coballin13
Sep 25, 2015 08:43 AM
