CV Boot
Old Jun 20, 2022 | 01:08 AM
audisfelicia's Avatar
CV Boot
Well my CV boot ripped and is flinging grease everywhere. Got the new inner boot from a local store. Was wondering what the best to get the axle away from the knuckle is? Should I be taking the lower ball joint off or take out the 2 bolts from the strut to the knuckle. I am trying to avoid having to do an alignment. Not sure if those are adjustable and affect camber...
Old Jun 20, 2022 | 01:16 PM
Taking the strut to knuckle bolts will be the easiest. There isn't a lot of camber adjustment with those bolts (unless you have added camber bolts). Going from memory you can mark the knuckle where it lines up so when you re-install you can get it back to the same position.
Shanman
Jun 12, 2016 09:46 AM
quikdcride
Aug 14, 2011 08:52 PM
dncalvillo2
Jul 31, 2011 08:06 PM
flash13brandon
Oct 23, 2008 01:34 PM
YelloEye
Dec 5, 2007 04:32 PM
