DC-2 Strut brace question
Old Dec 5, 2007 | 09:05 PM
Mike85220's Avatar
I am looking to get the DC-2 strut brace for my 07 Cobalt, but I have only seen pics of the single rod style braces installed in a Cobalt so far.
I want to make sure the clearances are fine for all that tupperware, and the DC-2 angles forward which is my concern for clearance.
Also, for the ones who have this brace, did you have to modify anything to get it to fit?
Thanks all!
Old Dec 5, 2007 | 09:07 PM
halfj99's Avatar
thats just a general pic, all dc bars for the balt are the single tube ones
Old Dec 5, 2007 | 09:12 PM
Fresh's Avatar
the PRODUCT DOES VARY. beware of this. several people purchased this bar thinking it would be the one pictured above...but it wasn't. one single tube.
Old Dec 5, 2007 | 09:21 PM
Mike85220's Avatar
Thanks for the clarification, I thought the dual bar one commanded a higher price from what I have been seeing when all this time it is the single bar.
Any mods to the car needed to get this to fit the Cobalt?
Old Dec 5, 2007 | 09:30 PM
Fresh's Avatar
nope, just a bolt on. you remove two bolts from the top of the struts on each side. slide in the bar, and bolt it back down. it's a bit of a tight squeeze but the bar will fit in there snuggly.
Old Dec 5, 2007 | 09:56 PM
D4u2s0t's Avatar
when you put it in, it will be a tight fit. if you lift the plastic liner by the rear of the engine bay, you can loosen a bolt that will make life much easier and give you way more clearance
Old Dec 6, 2007 | 07:32 PM
Mike85220's Avatar
Thanks guys for the tip.
I definitely will be getting the strut brace now.
Thanks
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
cavfiredesire
Oct 3, 2015 08:02 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
