Dear brembo pin
Old Apr 6, 2013 | 08:11 PM
krispy's Avatar
Dear brembo pin
Go die in a fire.
PB blaster
Hammer
Punch
Propane torch
Small MAPP/Oxy torch
nothing working so far, any other suggestions?
Old Apr 6, 2013 | 08:13 PM
turbosmart4's Avatar
New caliper. Lubricate pin. Problem solved.
Old Apr 6, 2013 | 08:14 PM
Cobalt_Daddy's Avatar
ya i heard these are a bitch. im afraid to even attempt to change my pads and rotors after not touching them since i bought the car.. 66,000km on them.
Old Apr 6, 2013 | 08:19 PM
Try to lubricate them before it happens to u
Old Apr 6, 2013 | 08:20 PM
you mean like a dab of penetrating/breakaway oil?
Old Apr 6, 2013 | 08:22 PM
krispy's Avatar
Passenger side came off with no real issues, I lubbed those up greatly (like I do with all brake parts). I didn't even know about the stuck pin problem until I got to the last pin and had to research it.
What a shitty design for US climates.
New caliper is one option, anyone ever have luck with moar heat (aim to heat the pin or the aluminum?) and moar pounding? Even if I put it back together the pads are now soaked with PB blaster ugh...
the reason its hard to remove is because it wasn't lubricated properly from factory... That's what I've heard
Old Apr 6, 2013 | 08:24 PM
krispy's Avatar
Likely cause is dissimilar metal corrosion effectively welding the spring clip to the caliper. Lube has a chance of getting between the metals and preventing that. I should bother my extended brother in law about this seeing how he worked on this brake program at GM.
Old Apr 6, 2013 | 08:28 PM
Tell him he should help u remove it
Old Apr 6, 2013 | 08:29 PM
gotboost?17's Avatar
Nothin Stock
mince was a 700$ at the dealer an i supplyed the brakes, now i do 2 brake service a year and tap tap there out,
Old Apr 6, 2013 | 08:39 PM
BlackLsCoupe's Avatar
new caliper and pin, anti seize the hell out of it. I do this to mine every 6 month since it happened to me
Old Apr 6, 2013 | 08:45 PM
09CobaltSS1's Avatar
^^this. The pins need a high temp antisieze, not so much a lube.
Something that worked for me was spraying the pins down with penetrating lube the night before and then going for a nice "spirited" drive right before doing the job to put some good heat in the calipers. Tapped the pins loose, had a beer while the brakes cooled down enough to handle and then went to town.
It's a good habit to also replace the pins and hardware every brake pad service too just to be safe. It's just cheap insurance.
Old Apr 6, 2013 | 08:48 PM
Sox-Fan's Avatar
Got Brakes?
pin kits from C.E.D. are 25 bucks a caliper. Just changed mine out recently.
Old Apr 6, 2013 | 09:01 PM
troof!!
Brembo Caliper Pin Kit 08 09 Cobalt TC 25900781
Old Apr 6, 2013 | 10:14 PM
buildmeanempire's Avatar
I just did mine recently and it was a bitch. I heated the hell out of those pins and also used P.B. blaster. I could only get them out a little bit so I had to punch them back in but then they came out pretty easy. I lubed them pretty good. I was gonna use anti-sieze but was unsure about it. Good to know it's safe and will be using that when I service the pins on my next oil change.
Old Apr 7, 2013 | 12:03 PM
krispy's Avatar
I just gave up for now and reassembled the caliper. I'll try again when I have spare pins, still not sure how to get the pin out short of a new caliper which really seems unnecessary for the problem at hand.
Old Apr 7, 2013 | 12:13 PM
cranemaster's Avatar
what if you take your time? spray in a little penetrating lube oil, take it real slow... then BAM one good thrust and your laughing.
Old Apr 7, 2013 | 12:15 PM
krispy's Avatar
I lubed it up many times with penetrating lube times, even let it try to work over-night and thrusted many times.
No laughing occurred.
I don't have a spare car and don't have spare parts so I can't get destructive at this point in time either.
Old Apr 7, 2013 | 01:39 PM
Powell Race Parts's Avatar
dear brembo pin I will make you krispy hot and you will get out of my life.
lol
PS get a new caliper, your pistons are probably corroded as well lol
Old Apr 7, 2013 | 01:52 PM
K-Train04RL's Avatar
just preheat the oven, and it will slide right in.... or out ... then back in ..
Old Apr 7, 2013 | 02:03 PM
Xmetalhead2003X's Avatar
A can of Free All and a bar of goodness, aka breaker bar. If not the bar, at least the Free All. Far superior penetrating fluid than Pb Blaster. Then anti seize them things.
Old Apr 7, 2013 | 03:10 PM
krispy's Avatar
How can a breaker be applied to get it out?
Old Apr 7, 2013 | 03:27 PM
Breaker bar? More forum help you dont need. You did fine, its just takes more heat than you used. The problem is that there is a point where you can potentially put enough heat in it to melt /wreck the caliper. It helps to have done it a few times...
Old Apr 7, 2013 | 04:31 PM
krispy's Avatar
Yea neither the propane nor the mini mapp torch I have throw out a lot of heat. I kinda wonder if a punch plus an air chisel could work if the pin was excited to a resonance frequency. (More of a thought experiment than anything)
Old Apr 7, 2013 | 06:06 PM
Yup more heat; the chance of the air chisel slipping off the 2 mm pin head is great. Therefore the caliper would be wrecked before you could even think about releasing the trigger. So the only excitement would be you cursing yourself
