does anyone make a direct bolt in strut/shock?
Old Jan 1, 2010 | 07:32 PM
Rodimus_Prime's Avatar
Ok so heres the deal, already got lowering springs, and im on stock shocks. I know that koni makes them however you have to hacksaw your stock ones in the front, they are inserts not a full kit. Does anyone make something you just bolt on?
Old Jan 1, 2010 | 07:34 PM
Cefaln452's Avatar
im pretty sure they dont... other than factory replacements
Old Jan 1, 2010 | 07:38 PM
TCguy's Avatar
Yeah exactly how do these work? ive been reading that you need to "modify" these.
Old Jan 1, 2010 | 07:41 PM
Cefaln452's Avatar
oh kyb makes a oem replacement... supposed to be better than oem
Old Jan 1, 2010 | 07:42 PM
Rippin07's Avatar
The changeover to the Koni's is really quite simple if your worried about the install.
Old Jan 1, 2010 | 07:43 PM
ls1fbody's Avatar
Haz l33t wheelz.
TC shocks are best.
Old Jan 1, 2010 | 07:44 PM
constantproject's Avatar
coilovers?
Old Jan 2, 2010 | 08:51 AM
The rear konis bolt in, the fronts you basically hacksaw the top half off then drill a hole in the bottom and the konis are a "insert"
Old Jan 2, 2010 | 02:14 PM
Maven's Avatar
GM makes some......they are what was used by the quickest real street FWD car to ever lap the Nurburgring. Pretty sure theyll be good enough
Old Jan 2, 2010 | 02:29 PM
Stiner's Avatar
http://www.zftna.com/sachs_usa
I think these guys make some
Old Jan 2, 2010 | 03:14 PM
ls1fbody's Avatar
Haz l33t wheelz.
Yep, they produce the OEM stuff.
i have a feeling you knew that though....
Old Jan 2, 2010 | 04:00 PM
Maven's Avatar
Actually IIRC KYB makes the fronts and Sachs makes the rears
Old Jan 2, 2010 | 04:39 PM
ls1fbody's Avatar
Haz l33t wheelz.
Well, that makes me half right then
Old Jan 2, 2010 | 06:13 PM
qwikredline's Avatar
some times you just make sense. ya know?
Old Jan 2, 2010 | 06:44 PM
Cefaln452's Avatar
kyb makes all 4 corners fyi
Old Jan 2, 2010 | 07:39 PM
How do I tell which is which crate engine dept just lists FE5 thats what they are all called my 07 says it has a FE5 too
Old Jan 2, 2010 | 09:26 PM
TCguy's Avatar
amen to that.
Old Jan 2, 2010 | 11:27 PM
Maven's Avatar
depends on the year, fyi.
you call and order ones for an SS/TC. come on...........
Old Jan 3, 2010 | 01:51 AM
ls1fbody's Avatar
Haz l33t wheelz.
Well, the rears i have say Sachs right on them haha
Old Jan 3, 2010 | 01:54 AM
kissrocker52's Avatar
im lowering my 2.4 with ksports and i was told all i needed was tc rear struts
Old Jan 3, 2010 | 01:58 AM
cli3e0339384398jk's Avatar
tc front struts. There is no struts on the rear
just shocks on back
Last edited by cli3e0339384398jk; Jan 3, 2010 at 01:58 AM. Reason: Automerged Doublepost
Old Jan 3, 2010 | 01:59 AM
what do i need in the rear then im not too educated on suspension
just shocks on back
Old Jan 3, 2010 | 02:01 AM
ok thanks
I'll help u with install if u want
