Dropped 2.2l problems!
Old Oct 20, 2013 | 07:11 PM
rhamilton909's Avatar
i dropped it on hr springs. it settles 2.5 inches all the way around and im hearing a popping sound when i turn the wheel left or right. it only happens sometimes and at low speeds. at first i thought it was axle bind so i emailed john powell on getting some motor and trans mounts. i read his rotated ones will fix axle bind? but he emailed me back saying if it a "popping" sound he thinks (it legit sounds like a pop) then its bushings. and that his alloy control arms and spherical cabs would fix it. he said they would be more durable than stock and laswt as long as i had the car. he also said theyd be complete in package. my question is if they are complete would it just be as simple as bolting new arms and thats it? and does anyone have an opinion as to whaT THEY think the popping sound it since i know almsot everyone is lowered here and what will fix it.
Old Oct 20, 2013 | 07:31 PM
Xmetalhead2003X's Avatar
If they're just bushings they may need pressed in unless you bought a complete arm with them already in. So it'd basically just bolt right in
Old Oct 20, 2013 | 07:32 PM
07cobaltLScoupe's Avatar
if it's more of a clunk sound i'd first replace your endlinks with Moogs if you haven't already
Old Oct 20, 2013 | 08:51 PM
how do i replace endlinks? and will it affect anything other part or will they need to be replaced eventually too? its a popping sound.
Old Oct 21, 2013 | 04:04 PM
bump!
Old Oct 21, 2013 | 04:13 PM
Still have the stock endlinks? (Rod that connects to the strut and the front sway bar)
Old Oct 21, 2013 | 06:07 PM
yes. everything is stock but the springs for suspension so far. i ordered better struts but they arent in yet. ive been told maybe ball joints. john powell said cab could be it. i thought maybe axle bind myslf. idk what to think.
Old Oct 21, 2013 | 06:11 PM
Mine used to do that too! I just never bothered with it since its so specific. Probably just a worn axle. I wouldn't replace anything until it becomes a more serious problem!
Old Oct 24, 2013 | 02:39 PM
my buddy is a mechanic told me it was the spring moving when i turn the wheel. it wasnt humming so no ball bearing and no play in wheel so not hub. he said i have worn out upper strut bearing. it happens on these cars as well as cab he said. so im replacing the upper strut bearing wiht kyp plates. and eventually powell contorl arms and spherical cabs mabe next summer
Old Oct 26, 2013 | 11:03 PM
qwank's Avatar
i was just going to say, i bet the bearing didn't seat correctly when the new springs went in. i see guys do it all the time.
Old Oct 26, 2013 | 11:22 PM
yeah i order kyb bearings. figure the upgrade and the fact they new wont hurt. i also am gonna ge moog tie rd ends becasue they are greasable and an uprade to handlinf as well as sway bar endlinks by moog. i jsut dont know what edlinks i need. there was 2 to choose from
Old Oct 27, 2013 | 12:25 AM
qwank's Avatar
get the shorter ones
Old Oct 27, 2013 | 03:17 PM
are tehy greasable? and its teh fe5 one then or 11inches one. thats all it said haha. ila ssume fe5
Old Oct 27, 2013 | 03:35 PM
Originally Posted by rhamilton909
are tehy greasable? And its teh fe5 one then or 11inches one. Thats all it said haha. Ila ssume fe5
fe5
Old Oct 27, 2013 | 04:00 PM
qwank's Avatar
fe5, they are 9.x''
ThoR294
Oct 4, 2015 08:44 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
