drum to disc conversion
Old Oct 28, 2005 | 12:23 PM
CobaltCowboy's Avatar
just got my LT and wanted to get big disc brakes front and back only problem is i got drums in the rear. is this gonna cost me an arm and a leg and where would i need to go to have it done?
Old Oct 28, 2005 | 12:37 PM
3fo893013L's Avatar
I've seen drum to disc conversions for Cavailers for about $300-$400. Don't think they cost that much for the Cobalt.
Old Oct 28, 2005 | 01:12 PM
Permafried-'s Avatar
This should give you an idea though RSM does tend to be a little more expensive than the compeition . Choose Cobalt on the left and it's about halfway down the page.
RSM
Permafried-
Old Oct 28, 2005 | 02:34 PM
VaMP's Avatar
It probably wont be an antilock brake system.... the kit shouldn't cost much just because it's rotors, calipers, and lines. However, unless you plan on doing it yourself, install could be hell...
Old Oct 28, 2005 | 03:33 PM
so the conversion wont work well with my current ABS? i dont want to lose my braking control.
Old Oct 28, 2005 | 03:42 PM
VaMP's Avatar
I don't think it would, I could be wrong though. But don't worry the rear wheels of cars rarely lock up, even when the ebrake is pulled. The front brakes are what you need to be worried about, which is why you have drums in the back.
Old Oct 28, 2005 | 03:47 PM
oh, cool, thanks for the quick replies. now i just need to decided on which brand i want to go with and what color. black would match my car but i am thinking polished would contrast well with the black bars on the wheels i am getting.
Old Oct 28, 2005 | 03:58 PM
VaMP's Avatar
No problem man, that's what forums are for
Anyone think that front rotors and calipers would fit the rear of an LS?
Old Oct 28, 2005 | 07:04 PM
05OrangeSS's Avatar
Unless you plan on cleaning you calipers like every couple hundred of miles I wouldn't go with the polished calipers. SSBC has a rear drum to disc conversion but I believe it's in the neighborhood of $1200, as of my own personal knowledge it's the only conversion kit out for the cobalts unless someone else has made one.
Old Oct 28, 2005 | 10:42 PM
Halfcent's Avatar
I'm old school
Arrow
To add to the above, the SSBC rear kit requires that the front kit be installed too. So now you are up into the $2000 range. AND, you have to have at least 17" wheels.
I actually will probably do this modification after my factory set of brakes is used up. By then I should have the larger wheels too.
Old Oct 28, 2005 | 11:14 PM
i was gonna go with 18"s and I plan on getting the front brakes done. I want more stopping power to offset the supercharger i plan on adding later.
Old Oct 29, 2005 | 12:28 PM
05OrangeSS's Avatar
SSBC doesnt require that you install the fronts. It's just recommended(cant spell) because it could ofset the braking balance.
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
09SSlow
Sep 28, 2015 12:37 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
