Eibach alignment kit
Old Feb 13, 2006 | 05:54 PM
Halfcent's Avatar
I'm old school
So I've done a little research on this issue a couple times now and have learned some new info that I needed to post. When Eibach first released their Pro-Kit and Sport-Line springs for the Cobalt, they didn't release an alignment kit with it. I called Eibach, and they told me directly at the time the factory alignment adjustablility of the Cobalt was enough that a kit wasn't needed.
So, thinking I was properly armed with the knowledge of the manufacturer, I would always jump into threads about this topic and tell people how they don't need a kit for Eibach springs on our cars.
Lately, I've been seeing some people advertising an Eibach Alignment kit (like J-Body Performance) and it immediately got my attention. I thought it might have been a scam part, so I looked into it again today.
I started with a call to Eibach again, who again told me that they don't make a kit for our car and didn't think one was necessary. However, he then gave me a phone number for Specialty Performance, and said they do some sub-contracting work for them with their alignment products. So I gave them a call.
Well sure enough, they are making the part that I have seen being advertised. They claim it is in fact a necessary kit for the Cobalt, and that they make it specifically for Eibach. So there appears to be a little bit of conflicting information out there.
So what I make of it is this; Our cars need the kit. Eibach simply hasn't updated their product catalogs yet to show the part, and Speciality Performance is in fact making it not for themselves, but for Eibach.
Front kit #81250
rear kit #75400
So in closing, I apologize to all those threads and posters who I told didn't need a kit, but you can be assured that I always follow up and check stuff out for ya'. Thanks.
Old Feb 13, 2006 | 06:21 PM
Chevypowered's Avatar
So this is not a camber kit but a toe-in type kit or what?
Old Feb 13, 2006 | 06:35 PM
Doc's Avatar
Doc
is this something that can be added after the fact..??
Old Feb 13, 2006 | 06:38 PM
YellowLT's Avatar
Any news on Eibach putting out a kit the includes shocks and struts
Old Feb 13, 2006 | 07:08 PM
Halfcent's Avatar
I'm old school
The front is a camber adjuster. The rear is for both camber and toe.
Yes it can be done after the fact. You should always do an alignment if you change springs. If you haven't done that yet, get the kit, and supply it to the shop that will do your alignment.
No word on anything having to do with struts or shocks.
Old Feb 13, 2006 | 07:15 PM
Doc's Avatar
Doc
Yes it can done after the fact. You should always do an alignment if you change springs. If you haven't done that yet, get the kit, and supply it to the shop that will do your alignment.
thanks, I read the directions and saw what it said.I remember what JapEater said too...he slotted his....
Old Feb 14, 2006 | 02:08 PM
celicacobalt's Avatar
soa re you saying an alighnment isnt enough with these?
Old Feb 14, 2006 | 02:29 PM
Halfcent's Avatar
I'm old school
These kits are needed when your alignment is accomplished. OR... at least that is what I am now learning. Like I said, originally I was told by Eibach that a kit wouldn't be necessary. I haven't installed my springs yet, but I went ahead and got the kits anyway so I have them incase they are necessary. Here they are...
First, this is the front axle kit:
You get 2 bolts per box. One for each front wheel. I didn't know that at the time, which is why I have two boxes. One will be getting returned.
Here is the rear kit:
You only get one of these per box (makes perfect sense, right?) This is quite an ingenious little device. It's a like a slide ruler, the inner circle spins and lines up with the outer circle to give you the desired amount of bevel. The instructions come with a chart that gives you where to set the dial, then you just cut out the tabs as needed to accomodate the mounting bolts.
The instructions did not have a template for the Delta platform car, only the J-body. I called Speciality and they said it would be the same, but I wouldn't cut out the tabs until I actually have the wheel off the car and check.
Old Feb 14, 2006 | 09:29 PM
There are two different parts for the rear camber and the rear toe, which one should we get??
Old Feb 15, 2006 | 12:14 AM
Halfcent's Avatar
I'm old school
71400 is a single set with several different single pieces of shim in different bevels. 75400 (pictured above) is a single piece that you can adjust to any degree of bevel. They both do the same job, just in different ways. You only need one or the other, not both.
Old Feb 15, 2006 | 11:48 AM
Mercury's Avatar
Awesome. I knew I wasn't crazy when I saw people's wheels leaning outward with the sportlines.
Good thing this kit isn't too expensive.
Old Feb 15, 2006 | 12:30 PM
SymbioteLT's Avatar
I have a 2006 LT model, does the kit work for me too or just the SS?
Old Feb 20, 2006 | 03:12 PM
Halfcent's Avatar
I'm old school
It will work on any Delta platform car.
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 28, 2015 12:51 PM
Sep 27, 2015 08:53 PM
