Eibach Front & Rear Sway Bar Kit
I wanted to see if anyone had the Eibach Front & Rear Sway Bar Kit installed on there car and if so would you recommend them for me? I am looking to stiffen up the steering of the car, I also with these would be replacing the stock shocks and spring.
Stay away from the Eibach sway bars. Just google it, lots of people have broken these sway bars. Powell hardcore rear sway and SSTC front sway is the best daily spirited drive setup.
Hmm did not think that Eibach made a bad part, so where could one buy Powell sway bars from?
PM Powell race parts on here. he will set you up. im in the process of buying a Rotated mount for my 2.4. and i would stick with your factory shocks/struts unless you are investing in coil-overs
Cool thanks and I planed on using the stock shocks/struts, was just going to change the spring to lower the car and change the handling.
DANRICKARD
Oct 1, 2015 12:08 AM
