End links question!!!
i believe so....i think the SS and the SS/SC have the same shocks so they have the same mount point....
correction...the struts/shocks are different...but i dont know if the mounting points are different....
no, and yes! its all well documented by Maven here, FE3 and FE5 are different lengths. Best is to go to PowergridInc.com links. specify Redline (they are the longer FE3 style) and you will be good, or go to FE5 lengtht, (replace the pair) wont be a problemI think. Maven can chime in here he is waaaaaaaay more experienced with the FE3 /FE5 interchange stuff....our good friend in Alabama is generally correct as well, but do you trust a guy who drives a Scion TC but has to hang with his old buddies on ****.net? I think those Scion forums are a prolly bunch of ghey snobs doncha know? And if you live in QC it wont be warm until July so you got time ....jk
With an SS/2.4 you can run whatever endlinks you want. Just make sure you always install them in pairs because you can fit the long or short ones.
FE5 stock: quality replacement type upgrade
Bwoody and all the other massive shaft aftermarket ones: they work, but may be a bit overkill and have an unknown wear life.
Powergrid: top of the line, no question.
but your right...most scion forums are gay....
and just about everything i have learned i learned from you and maven... so
