Endlink length matter much?
Old Dec 20, 2010 | 10:12 PM
KINGKOLE's Avatar
Stock endlinks from bolt center to bolt center is 9.5 inches and the new ones I got are 13.5 inches long is this better worse????
Old Dec 20, 2010 | 10:21 PM
CordiaDOHC's Avatar
It sounds like you had the FE5 ones and now you have the FE1/FE3 ones. If lowered it could cause issues. I know when I upgraded from FE3 links to FE5 links I picked up some steering response and although I cant tell for sure it felt like it was a bit stiffer in the turns.
In other words take them back for the correct length.
Old Dec 20, 2010 | 10:25 PM
C_A_D88's Avatar
get power grids
Old Dec 20, 2010 | 10:26 PM
CordiaDOHC's Avatar
Originally Posted by C_A_D88
get power grids
powergrids arent truly worth the money unless your autocrossing.
For 90% street duty save yourself 100 bux and just run moog FE5 (SS) endlinks. They are beefy and come with a grease fitting much better than the stock pieces.
Old Dec 21, 2010 | 12:36 AM
KINGKOLE's Avatar
Good call that sounds about right to me! Thanks for the help!
Old Dec 21, 2010 | 02:29 PM
Wangspeed's Avatar
Try to set the sway bar ends (not end links) to be close to parallel to the ground. For me, that means shortening the end links. Easiest way to do this is to drive the car onto a ramp of boards and adjust/look from underneath.
Old Dec 24, 2010 | 09:49 AM
qwikredline's Avatar
^^^ this. and to answer the OP shorter length isbetter the link is stronger. Powergrids are the best hands down, like Chris said...
Old Dec 24, 2010 | 09:55 AM
mmcgee123's Avatar
Dosnt matter if ur replacing both but if ur just doing one then yes
Old Dec 25, 2010 | 11:02 AM
Maven's Avatar
it does matter if youve got an FE5 car.....dont use long links on a short link car.
Old Mar 27, 2011 | 11:49 AM
ecot3c inside's Avatar
I know this is an old thread I'm bumping, but my one endlink keeps popping off. I don't overtighten it and I'm lowered pretty good I think they might be too long? I have no idea why it is doing this, it'll stay on good for like a week then just random *pop* and it's laying on the control arm.
Old Mar 27, 2011 | 12:14 PM
CordiaDOHC's Avatar
Not sure how bolted on item is popping off.
But replacing them with the moogs is cheap (60 total) and they are greasable.
Old Mar 27, 2011 | 12:59 PM
I have no idea either, only thing I can think of is it isn't aligned correctly?
Solaris99
28
Mar 15, 2017 01:22 PM
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Stuff
Oct 1, 2015 05:47 PM
goaliemo
Sep 28, 2015 01:37 PM
