Endlink question
Old Jun 22, 2011 | 10:14 PM
2007victoryred's Avatar
Endlink question
I was wondering if the moog endlinks for the fe5 will fit the fe1... Any help will be appreciated!
Old Jun 22, 2011 | 10:16 PM
agita_san's Avatar
It should work just fine...
Old Jun 25, 2011 | 03:36 PM
nimble's Avatar
Don't mean to jack the thread but i was wondering this too. I have the cheap dropzone springs on an Ls. I purchased some links from autozone that are fe1's even though i asked for ss links! So i had to jack up the wheel just so they would fit. My question is am i doing damage that way and will my ride be better with ss shorter links???
Old Jun 25, 2011 | 03:51 PM
07BoostedG5's Avatar
well its still not right, the only way to have it all square is with fe5 strut/shocks, fe5 spring or lower then an adjustable endlinks on its lowest setting and then your toe set to Zero.
Im literally in the middle of installing pedders with power grid endlinks right now
Fe5 links are garbage the stud was free spinning so I had to put a vise grip on the bolts shaft to get the nut off, Honestly never had that happen with fe1's, so if your just replacing stock, keep the fe1's there better for whatever reason.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
