FE5 on an ls align???
Old Apr 6, 2009 | 08:35 AM
beamer1341's Avatar
should i get an alignment if im just putting fe5 springs in? should only be an inch drop
Old Apr 6, 2009 | 03:50 PM
DaBuzzard's Avatar
Maybe 1/2" drop from fe1 to fe5, should be none at all if you believe GM's ride hieght specs. Should handle much nicer though
I make a point of having the alignment done after any work that involves removing / replacing front suspension parts but I'm a bit **** that way , probably be fine if just spring r&r.
Old Apr 6, 2009 | 03:52 PM
jschatte's Avatar
You need to get an alignment.
Old Apr 6, 2009 | 06:52 PM
Maven's Avatar
Yes if you disassemble or replace any parts that affect you alignment you should get it checked/set. Youre doing both, removing the struts, and replacing springs, get an alignment
Your looking at a 1/2"-7/8" drop in front, and 1"-1 1/8" drop in rear. The ride heights are the same because of tire differences, the suspension member trim heights(spring heights) are significantly different however.
Old Apr 7, 2009 | 02:37 PM
DaBuzzard's Avatar
Wow, didn't think it was that much difference at the rear but looking at a stock ls in the parking lot....ya, that thing has the ass way up in the air. And the little tiny rims and tires sure don't help Was kind of assuming that the op was going to 17 or 18" rims too....guess he didn't say that though.
Old Apr 7, 2009 | 03:27 PM
beamer1341's Avatar
yeah forgot to mention ive got 17's on
Old Apr 7, 2009 | 11:18 PM
Maven's Avatar
doesnt matter.
DANRICKARD
Oct 1, 2015 12:08 AM
Coballin13
Sep 25, 2015 08:43 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
ROADKONE
Sep 9, 2015 02:32 PM
