FE5 Strut on SS/SC? Or better choice?
Old Feb 23, 2009 | 02:41 AM
nairmaro's Avatar
I just bought my 06 SS/SC and sadly have to replace the Front Struts....Im familiar with the SS/SC FE5 struts due to the rants and raves of car and driver. are the FE5's a direct replacement for a SS/SC model? if so, is it worth it? im looking to spend around $150 a piece and consider my car a daily driver...thanks in advance
**Stock height
Old Feb 23, 2009 | 02:43 AM
SlowBalt_06's Avatar
look into the cobalt ss.tc struts it would be an upgrade
Old Feb 23, 2009 | 10:16 AM
nairmaro's Avatar
No doubt im getting a pair. Rockauto.com sells them very cheap ($91) and if you consider it an upgrade then im down. I this a common next step or does everyone go to coil overs instead?
Old Feb 23, 2009 | 10:17 AM
D4u2s0t's Avatar
i'm not sure of the question... the fe5 struts are what is on the cobalt stock...
Old Feb 23, 2009 | 11:28 AM
nairmaro's Avatar
I have a 06 SS/SC, i thought that only the Turbo Charged Cobalts had the FE5 setup otherwise the older models use FE1. Either way i think ill buy a set of FE5's. Thanks for the help.
Old Feb 23, 2009 | 11:49 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
The FE5 is on the SS/SC and the SS/TC. The TC FE5 has however been tweaked/improved.
Old Feb 23, 2009 | 12:00 PM
ls1fbody's Avatar
Haz l33t wheelz.
what Rod says...
Old Feb 23, 2009 | 11:45 PM
Maven's Avatar
SS/SCs already have FE5, SS/TC have DIFFERENT FE5. You want SS/TC FE5 if youre looking for an upgrade. If they are $91 they are proly SC type FE5
Old Feb 23, 2009 | 11:47 PM
2007victoryred's Avatar
Where would be the best place to find the ss/tc fe5's
Old Feb 23, 2009 | 11:51 PM
Maven's Avatar
gm parts dealer.
Old Feb 23, 2009 | 11:53 PM
How much do you think it would be for the shocks and struts?
Old Feb 24, 2009 | 12:12 AM
nairmaro's Avatar
Makes sense that the FE5 has a 2nd generation. So then what is the FE1 that is listed on Rock auto? There more expensive then the FE5's.....Regardless, im getting the TC version
Old Feb 24, 2009 | 04:47 AM
trasher's Avatar
Are you just replacing the 1 blown strut? If so just get the original FE5 to match the setup. If youve got the money it would be a nice step up to the TC setup all around
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
jas09ss
Sep 26, 2015 01:06 PM
Coballin13
Sep 25, 2015 08:43 AM
