FE5 Sway Bar
Old Feb 13, 2010 | 05:08 PM
Chase0224's Avatar
FE5 Sway Bar
I just ordered the FE5 front sway bar with bushings and clips, and moog endlinks to go with my FE5 Shocks and struts and OTTP street bar. Anyone have a how to to install the front sway bar, i heard its a complete bitch, any tips? I will be using air tools so it will help.
Old Feb 13, 2010 | 05:13 PM
OBZ's Avatar
OBZ
The front is pretty easy remove your front tires, Downpipe, transmission mount & bracket (15 & 16M). And the 2 end link bolts(18M) . I just did this about 2 weeks ago.
The rear really only takes 15 minutes. It's very helpful to ziptie it in place also.
Old Feb 13, 2010 | 05:15 PM
qwikredline's Avatar
ya good advice. go in the passenger side....
Old Feb 13, 2010 | 05:23 PM
Chase0224's Avatar
can i do it without removing the downpipe? and does it just slide out? Im not worried about the rear, i know it just bolts up. Im good at working on suspension, but ive never gotten into the sway bars, i can change springs in record times i swear. Ill do it when i put in my stage 2 mounts, sounds like a perfect time to do it.
Old Feb 13, 2010 | 07:34 PM
4 sure with the rear mount out it will be easier.
Old Feb 13, 2010 | 07:46 PM
Boosted_Cobalt09's Avatar
^^what he said.
Old Feb 13, 2010 | 08:30 PM
XgunsmokeX's Avatar
doing mine this saturday
Old Feb 14, 2010 | 01:37 AM
007CobaltLS's Avatar
If any of you can take some pics of a little bit of your work, I would greatly appreciate it (and so would many others).
I'm debating on doing this...depends on how much I really want to mess with the front end (I will be doing struts and shocks...SS/TC, and steering rack spacers this summer some time so that would probably be the time to do this). OP where did you get your parts and what did you pay?
Old Feb 14, 2010 | 02:23 AM
Chase0224's Avatar
I paid like 140 shipped for the sway bar clips and bushings, from CED. Ill deff post up some pics and maybe a how to once i do it. Should have the mounts in sometime next week with the bar so it will probably be put in friday night.
Old Feb 14, 2010 | 03:04 AM
NWAE Cobalt's Avatar
you dont have to take the sway bar off
just take the tires off, remove the endlinks, take the subframe up front and drop the bolts down most of the way (leave a few threads in) after taking the bolts out of the two tranny mounts
then just pull the brackets holding it down.....and swap..then reinstall new one
shouldnt take too long at all
Old Feb 14, 2010 | 09:17 AM
XgunsmokeX's Avatar
dammnn 140? i paid 44 for bar,12 for bushings and like 50 for endlinks. idk a shop is putting mine in.cuz 1 person says drop frame,another says DP, another says pull out from passanger tire
Old Feb 14, 2010 | 09:30 AM
LS6Rally's Avatar
forgive me if im being dumb, but you have an SS/SC right? wouldnt that already have the FE5 suspension?
Old Feb 14, 2010 | 09:33 AM
XgunsmokeX's Avatar
who me? im a LS
Old Feb 14, 2010 | 09:38 AM
the biggest issue will be: do you drill and install the FE5 2 bolt bushing bracket? Good luck with that...if you dont, over time the single bolt and tab bracket will yield and the bar will b ecome ineffective...
Old Feb 14, 2010 | 09:44 AM
LS6Rally's Avatar
who me? im a LS
no the OP
Old Feb 14, 2010 | 09:50 AM
XgunsmokeX's Avatar
umm 05 are a one bolt clamp and so is it on my 07 balt my car.
Old Feb 14, 2010 | 01:43 PM
Chase0224's Avatar
Nope it has the FE3
Yeah 137.55 shipped. 51 for the bar, 27 for the clamp, and 14 for the bushings.
Old Feb 14, 2010 | 03:54 PM
Nope it has the FE3
This is confusing me as well...if you have an SS/NA it would have FE3, if you have an SS/SC it would have FE5 LSJ, if you have an SS/TC it would have FE5 LNF...so you are upgrading from LSJ to LNF stuff aren't you?
How does an SS/SC come with FE3 equipment?
Old Feb 14, 2010 | 03:59 PM
ls1fbody's Avatar
Haz l33t wheelz.
Nope it has the FE3
If you have an SS/Sc that was supercharged from the factory, you have the FE5 system. Unless you felt like upgrading to the FE5-s (turbocharged car) stuff for ***** and giggles...
Old Feb 14, 2010 | 04:08 PM
Chase0224's Avatar
Wait yeah i do have the SSSC, but i was under the impression that it was FE3, and that the TC was FE5. So my shocks and struts to the FE5 wasnt an upgrade and the sway bar isnt an upgrade? Well it looks like ill be returning it, my shocks and struts needed replaced anyway.
Old Feb 14, 2010 | 04:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
no they were both upgrades. The TC's have different valving in the shocks, and the SS/Sc bar is 24mm, the TC is 25. It was an upgrade, but i doubt you actually feel the difference.
Old Feb 14, 2010 | 04:14 PM
Chase0224's Avatar
okay so its pointless to spend the 137 bucks on the new bar?
Old Feb 14, 2010 | 04:17 PM
ls1fbody's Avatar
Haz l33t wheelz.
pretty much. It'll help, but it's not that much of an upgrade from the SS/SC bar. For an ls or lt, it would be.
Old Feb 14, 2010 | 04:19 PM
Chase0224's Avatar
thanks for saving me 140 bucks i appreciate it. Any other suggestions for suspension or any other kind of use on my car. This is the first time ever that i cant find anything i need to buy for it. It kinda freaks me out.
Old Feb 14, 2010 | 04:22 PM
CordiaDOHC's Avatar
Ive heard the TC bar is a slightly different shape but havent seen pics of it to confirm or deny this.
