Fe5 sway bar question
In the midst of an fe5 swap and following the how tos I can find. However, I haven't removed the down pipe and I can't get the bar to rotate down into position. Is the downpipe removal a must, or is there other tricks/something I'm missing here? Thanks.
When I did my sway bar swap I ended up lowering the subframe to get the clearance I needed to remove the sway bar.
If you Google "maven sway bar swap" you should see a ecotec website with his how-to. I think that's the one I followed if I remember correctly.
I removed the rear transmission mount completely, tie rods and that's it. I didn't remove the down pipe because I didn't feel it was necessary but I'm running out of ideas, except the frame
Just did this yesterday. Loosen front sub frame bolts. Remove the rear sub frame bolts completely and then remove the transmission mount bolts. You should now be able to pry to sub frame down enough to pull out the sway bar and put new one in.
DANRICKARD
Oct 1, 2015 12:08 AM
