Front end clunk
Old Apr 28, 2015 | 05:47 PM
Jesse1991's Avatar
Front end clunk
I have a 2008 Cobalt Sport. Last year the clunking started rear CAB's and sway bar end links fixed that. After winter this year it returned. I replaced the struts and it is still there. Had it into shop tonight and they can't find anything. They checked sway bar bushings, tie rods, ball joints, perhaps loose nut on new quick strut. I am now at a loss for what it could be. Any thoughts?
Thanks
Old Apr 28, 2015 | 07:14 PM
crispino's Avatar
Control arm bushings, nutorious on cobalts, just follow the control from the lower ball joint to the frame, it's a round donut looking rubber bushing, usually cracked and separating, under load you won't be able to wiggle it though.. easy miss if you don't know what you're looking at
Old Apr 28, 2015 | 08:17 PM
double clutch's Avatar
He said he replaced cabs already.
OP there are like 1000 threads on steering clunk. Check ur intermediate shaft for play. Could be your rack also
Old Apr 28, 2015 | 08:28 PM
LNFTX's Avatar
Steering intermediate shaft
Steering rack
Sway bar bushings
Strut mount/bearings
Rear trailing arm bushings
Also if your struts were not aligned properly with the mount/bearing clunk city
Old Apr 29, 2015 | 04:12 PM
crispino's Avatar
guess I scanned too quickly lol
Old Apr 29, 2015 | 04:25 PM
One hard winter can destroy the OEM CABs
Old Apr 29, 2015 | 07:24 PM
Jesse1991's Avatar
The struts were replaced with quick struts so there should be a problem with them and the CAB's were replaced with MOOG one's.
How do I check intermediate shaft for play and as well as the rack?
I am finally getting the ignition recall done next week if I can't find it by then hopefully the dealership does.
Thanks
Old Apr 29, 2015 | 07:48 PM
Shake ur steering wheel back and forth and see it u hear the noise
Old Apr 29, 2015 | 07:52 PM
LNFTX's Avatar
To check the rack disconnect the intermediate shaft and outter tie rods and move back and forth using the tierods checking for binding.
As for the shaft there is no fool proof way to check it in place removal and inspection of the u joints is really all to do also make sure the bolt is good and tight with red loctite mine would loosen of causing the intermediate shaft to move on the shaft sticking out of the rack causing a clunk
Old Apr 29, 2015 | 08:32 PM
rreineck's Avatar
I had a similar problem in my SS. Loud pop when starting from a stop and during turns...replaced the whole control arm and the problem went away.
Old Apr 29, 2015 | 09:48 PM
CudaJoe's Avatar
Im clunking now that I have my new wheels and tires on. When rolling at 30mph and juggling the steering wheel back and forth I can hear the clunks. Thinking sway bar end links, bushing should fix it
Old May 2, 2015 | 07:59 PM
Jesse1991's Avatar
I put my summer tires back on today. I started with the rear and low and behold I had a broken driver side rear spring so I replaced both rears. I looked through the front end again didn't find anything that stood out. If I grab the intermediate shaft? (between steering wheel and steering rack) at the u-joint I can twist it a bit and move the rack back and forth a tad and hear a knock/clunk/click from the other side. When driving though and turning the steering wheel quick I can't replicate the sound it makes when hitting bumps.
Old May 2, 2015 | 10:36 PM
random_letters's Avatar
Plastic gear in the steering column?
Mine sounds like the front end is falling out going over bumps 1 wheel at a time. Cant feel it in the wheel, but can feel it in the pedals for some reason.
Old May 4, 2015 | 05:04 PM
Foximus's Avatar
Make sure the rack is fully tight. I had the bolts start to back out of the subframe and that was causing my clunking.
Old May 5, 2015 | 03:08 PM
crispino's Avatar
My toe was off.. like wayyy off.. since the alignment adjustments it went away, thankfully lol, appreciate all the help !
Old May 6, 2015 | 07:01 PM
Jesse1991's Avatar
Had my car in for ignition recall today and got them to look at the clunk. The steering column needs to be replaced (backlash in gears) I can hear it but it isn't the clunk I am worried about. They say the quick strut I put in brand new 3 weeks ago is gone. The noise was there before the new strut and there after. Unless the original strut was blown and the new one I replaced it with was garbage it doesn't add up. I took their receipt to parts store and got a brand new right front strut under lifetime warranty and will have to swap it out and see if it's the issue.
Old May 11, 2015 | 01:36 PM
CudaJoe's Avatar
I think I figured out my clunk as well maybe. Took the front wheels off and tried move all the components. Surprisingly everything felt solid in the swaybar, swaybar endlinks, control arm. I couldnt move any of it.
The right axle can slide back and forth (3-4mm) and makes a slight clunking sound but not at the loudness I hear it when driving. The rotors rotate in place a bit too banging against the studs. Not the same loudness of clunk I hear but similar.
So I bolted the wheels on as tight as I can with the provided lug nuts with the car on jack stands, the clunking is now nearly gone. Can still hear it some what. Im wondering if it has to do with how the aftermarket wheels sit against the hub assembly? Is that a thing?
Old May 11, 2015 | 02:14 PM
exninja's Avatar
IOW, are you saying that you think that tightening your lug nuts may have helped?
Old May 14, 2015 | 11:32 AM
CudaJoe's Avatar
I dont think I was able to tighten them when they were on the ground because of the fancy tires. I was able to tighten better when the car was up. The clunking is still there, it was a figment of my imagination unfortunately
I cant find any clunking or banging in any of the suspension components when I give them a shake. I think I need to bring the car in to get checked out unfortunately.
Old May 14, 2015 | 11:39 AM
exninja's Avatar
Have you check the intermediate steering shaft?
If you take it in or otherwise figure it out, please let me know. Mine clunks when turning left and hitting a bump.
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
