Clunk
Old May 15, 2015 | 12:52 PM
Olybaltss's Avatar
Clunk
I had the dreaded front end clunk, and I've gotten around to replacing end links and sway bar bushings so far. it seemed like the clunk stopped for a day or two, then came back twice as loud. it wasn't so much during normal driving, but more moving from a stop, not smooth shifts, so i thought it might be something loose that i replaced. checked it all and it's good and tight. after another few days, the clunking stopped.
Anybody have any ideas as to what to look at/why it would have stopped on its own? i have CABS, leading and trailing, that will go on next, i just thought that the clunk started/stopped on its own was weird and wanted to ask opinions.
Old May 15, 2015 | 01:13 PM
exninja's Avatar
Have you ever replaced the CAB's?
I did and even though they needed to be replaced badly, the clunk was still there. My next guesses are a binding intermediate shaft or strut mounts. I'm pretty sure my shaft is seized because when i replaced my engine the collar would not separate until i started dropping the cradle. There was no play at all. Hindsight I should have replaced it then, but I had no idea that was an issue until I saw another thread about it.
Old May 15, 2015 | 01:22 PM
ATOMbomb's Avatar
I have front end clunking aswell. Mine seems to be fine and not make a sound someone days while other days There is a sharp clunk sound.
Old May 15, 2015 | 01:25 PM
CudaJoe's Avatar
I have a clunk as well. My clunk happens mainly at low speeds and going over bumpy surfaces. PPretty much gone at high way speeds.
Old May 15, 2015 | 01:58 PM
Olybaltss's Avatar
Mine is a pretty sharp clunk as well, not subtle or "light" by any means.
I haven't replaced the CABS yet, which had me thhinking that was likely the cause, i just haven't gotten around to pressing the old bushings out. I was thrown off by it starting/stopping on its own, that was why i thought to post and ask for thoughts.
Good call on checking those, i'll make sure i do when i get under there.
marquis
Aug 29, 2019 06:07 PM
Sean Cummings
Sep 11, 2015 09:35 PM
hispano1
Apr 27, 2007 10:35 AM
Blown 4-banger
Nov 8, 2006 10:58 PM
edash
Feb 23, 2006 01:12 PM
