front end noise fix
Old Apr 16, 2012 | 02:02 PM
j27-2's Avatar
front end noise fix
I have been having problems with a noise in my front end that sounds like a hammer hitting the sub frame for a while now. I have a 07 ls sedan which I have put an fe5 sc front sway bar in with moog fe5 end links. I have been replacing control arm bushings, strut mounts, and end links in search of this noise.
I finally found what the problem was and it was the one bolt sway bar mounts. The mounts use a metal tab that inserts into the sub frame and when I took them out I could see shiny spots on them where they where rubbing. I rapped the metal tab with electrical tape reinstalled it and walla the noise is gone so this might be worth looking at if you are having front end noise.
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
