front sway bar upgrade.
Old Jun 7, 2008 | 12:16 AM
mrsilent13's Avatar
http://www2.partstrain.com/basket.php
i just found this...and im looking into buying this upgrade for my balt. what do you all think?
Old Jun 7, 2008 | 02:42 AM
IonNinja's Avatar
unless you guys like understeer, i wouldn't even bother with a larger front sway bar
Old Jun 7, 2008 | 02:57 AM
mrsilent13's Avatar
so what your saying is dont get this kit....i dont understand how it will understeer...please explain
Old Jun 10, 2008 | 07:59 PM
montecarloman's Avatar
Generally when you stiffen the front suspension you will cause an increase in under-steer. Same principal for the rear, stiffen the rear and you will introduce more over-steer. The trick is to feel what the car is doing and make the adjustments accordingly. Front wheel drive cars have under-steer inherent in there design and typically production cars have under-steer designed into them as a pseudo safety feature. Thats why typically you will see people installing the rear add-on sway bars as apposed to full kits. The rear bar stiffens the rear suspension there by adding over-steer and changing the handling characteristics of the car. The Eibach kit listed on that website states it has a 27mm front bar and a 25mm rear bar. Personally I think that combo would work because the rear bar would add to what the factory trailing arm has welded into it already. The only problem I can think is if the front 27mm bar is hollow. That would make it a bad choice in my opinion.
Old Jun 10, 2008 | 10:03 PM
mrsilent13's Avatar
so this would be a good kit to buy?
Old Jun 10, 2008 | 10:34 PM
OrngBalt's Avatar
someone contact alleycat. She has had a PROFESSIONAL AUTO CROSSER tell her straight up. The cobalts could afford a larger diameter front sway and it will only help with handling. many AutoX'ers unhook their front sway during competition, but this guy suggested the absolute opposite. A front sway bar upgrade is a good thing for this car
Old Jun 10, 2008 | 10:39 PM
mrsilent13's Avatar
hmmm interesting....i think i will get this upgrade then
Old Jun 10, 2008 | 11:18 PM
JohnyNFullEffect's Avatar
does the SS N/A have the same front bar as the SS/SC?
Old Jun 10, 2008 | 11:37 PM
mrsilent13's Avatar
no...the ss/sc bar is a bit thicker
Old Jun 10, 2008 | 11:41 PM
OrngBalt's Avatar
https://www.cobaltss.net/forums/suspension-67/fe3-vs-fe5-misinformation-61284/
Old Jun 11, 2008 | 09:29 AM
  #36
cool thanks!
Old Jun 15, 2008 | 05:08 AM
  #37
SWmaster's Avatar
Those autoXers are morons. They are the same people that buy a wood volume knob for "warmer" sound.
The whole point of a sway bar is to reduce camber changes due to body roll and keep more of the tire surface in contact with the road.
Old Jun 15, 2008 | 05:38 AM
  #38
ls1fbody's Avatar
Haz l33t wheelz.
according to eibachs website, the fron is 29mm and the rear is 25mm
http://eibach.com/cgi-bin/htmlos.exe...29218400022040
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
n20saturn
Sep 30, 2015 12:26 AM
