g6 knuckle same as competition knuckle?
Old Sep 14, 2011 | 09:47 AM
SaberD's Avatar
came across this thread:
https://www.cobaltss.net/forums/part...nuckle-195755/
are the g6 knuckles the same as teh competition knuckle for the cobalt?
Old Sep 14, 2011 | 10:06 AM
SaberD's Avatar
I also have read that the competition knuckle was derived from the g6 knuckle. if so, what modifications would need to be made to the g6 knuckle to make it work on a balt?
Old Sep 14, 2011 | 10:18 AM
MastaShaKe_88's Avatar
hmmm yea 'im in for info
Old Sep 14, 2011 | 10:54 AM
Powell Race Parts's Avatar
G6 knuckle required some machining. competition knuckle is machined. Unless you track your car, dont worry about it. Better still upgrade to LNF knuckle but requires modification and machining for lsj cars to use the axles and retain abs as it needs a wheel bearing change to use the axles and keep abs etc.
Old Sep 14, 2011 | 12:58 PM
SaberD's Avatar
Yeah sounds like it would be easier to machine the g6 knuckle than to go with the lnf setup. I have access to a cnc/manual bridgeport mill, a drill press, manual lathe, and also some 3 and 5 axis laser machines, so all I need to know is what needs to be machined on the g6 bracket. Any faces that need to be machined, or holes that need to be reamed, I can take care of. However, if any of the holes in the g6 knuckle are too large, that may pose an issue.
are all the g6 knuckles the same?
Old Sep 15, 2011 | 09:27 AM
SaberD's Avatar
bumpity
Old Sep 15, 2011 | 09:22 PM
I got a set of brand new G6 knuckles you can have cheep. email me thanks
john@powellraceshop.com. quote screen name as well as real name so I can remember this post lol
Old Sep 19, 2011 | 03:14 PM
SaberD's Avatar
i guess nobody knows. maybe ill visit a junkyard and pick up one to see the differences. probably wont happen anytime soon though unless i break the stock knuckle :P.
Old Sep 19, 2011 | 09:09 PM
Wangspeed's Avatar
Apparently you don't read. John already answered you.
Old Sep 19, 2011 | 09:48 PM
SaberD's Avatar
uhh nobody has specified what needs to be machined on the knuckle. nor has anyone confirmed that all years/trims of g6 knuckles are the same.
footballplaya3k
Sep 28, 2015 11:14 AM
royce777
Sep 28, 2015 07:11 AM
Cptnslo
Sep 24, 2015 09:32 AM
ncstateredline
Sep 10, 2015 07:22 AM
italstalnprd86
Mar 23, 2006 06:20 PM
