GRAVANA LAUNCHES NEW H&R SPORT LOWERING SPRINGS FOR THE COBALT SS SUPERCHARGED COUPE!
Old 01-23-2006, 11:27 AM
Gravana1's Avatar
Originally Posted by ExHondaMan
Is that like Pre-Order you take the money and we wait for the product... Or go the list type.
On this type of Pre-Order, we will take orders, but we don't process your card until the items ship. For people paying with checks, cashier's check and money orders, the money is deposited immediately due to time limits on cashing.
Jim
Old 01-23-2006, 10:29 PM
Domestics Pwn
ExHondaMan's Avatar
Jim
Im down for the Coilovers.... although i doubt 29 others will be
Old 01-24-2006, 11:45 AM
Gravana1's Avatar
FREE H&R SPRINGS
BY THE WAY, IF YOU ARE LOCAL TO GRAVANA, WE ARE LOOKING FOR A 2.4 SS COBALT TO USE IN ORDER TO TEST THE H&R SRPINGS. PLEASE EMAIL US IF YOU CAN BRING YOUR CAR TO US IN SANTA CLARITA, CA. WE WILL NEED THE CAR FOR ONE DAY AND YOU CAN CHOOSE WHICH SPRINGS YOU WANT TO KEEP ON THE CAR.
Old 01-24-2006, 12:00 PM
Ghalterman_usmc's Avatar
Count me in for the Coil overs list.....if there under $1400
Old 01-28-2006, 12:45 PM
ComputersAre8ad's Avatar
Dumb question maybe, but what exactly are Coilovers?
--Still a n00b to car... stuff--
J
Old 01-28-2006, 01:02 PM
J
By Philip Royle
Photography: Philip Royle
So, what are coilovers? Most people know they’re expensive, race cars use them, they’re expensive, some show cars have them, and they’re expensive. In the simplest definition, coilovers replace the stock shocks, struts, and springs on a vehicle and enable ride height and weight distribution to be adjusted with minimal effort. Most coilover systems also allow shock compression rates to be altered through the turn of a knob. One of the best features of coilover systems is how easy they are to install—many manufacturers ship their coilovers pre-assembled. But there has to be more to it, right?
Coilovers were designed with the racetrack in mind and performance as a primary concern. Through the use of scales that measure the amount of weight each tire supports, coilovers can be manipulated through compressing and uncompressing springs to give the vehicle more desirable weight distribution. No problem, right? This straightforward concept turns more complicated when a specific weight distribution is desired.
During cornering, weight transfers across the chassis diagonally. In other words, when entering a left-hand turn, weight travels from the left-rear to the right-front of the vehicle. This fact also holds true when adjusting coilover systems to achieve a desired corner weight. For simplicity’s sake, we’re going to use an example utilizing a Utopian car weighing 3,000 pounds. We’re also going to discount the driver’s weight and assume the car is perfectly symmetrical. By putting the car on scales that weigh each corner of the vehicle, we see that the left-front weighs 950 pounds, and the right-front weighs a similar 950 pounds. On the rear, both the left and right weigh 550 pounds.
Plain and simple, corner weighting is a difficult task that is time consuming (And did we mention difficult?—MAX). The process is so complicated that you must actually use some of the knowledge you attained in your advanced placement physics class in high school. The concept is fairly straightforward, but the actual practice will kick your butt. As we said, weight transfers diagonally, so the coilovers must be adjusted with the knowledge that when you adjust the right-front, the left-rear will be affected, too. But it doesn’t end there. Let’s say, for instance, that the right-front coilover spring is lowered. What affect will that have on the left-rear? When the spring collar is lowered, the weight resting on that corner will decrease. The weight resting on the diagonal wheel will, more often than not, decrease as well, but the weight resting on the other two wheels will be force-increased, depending on the chassis design. Each adjustment affects every corner, and that’s why the process of corner weighting gets so immensely complicated. In our hypothetical example, if we wanted to decrease the weight on the right-front wheel, the spring collar should be lowered. The weight on that wheel would decrease beneath 950 pounds, the diagonal wheel should decrease beyond its resting 550 pounds, and the left-front and right-rear resting weights should increase accordingly, as there must always be a constant weight pushing on the ground in a stationary car. A lot of little adjustments must be made at each corner, and detailed records must be kept in order to find out what worked and what didn’t and by how much.
This aside, let’s face reality: A great number of people purchase coilover systems for use on their show cars. In the case of show cars, coilovers are ideal because the suspension can be slammed at the show with few tools, then raised again for the drive home. After a car show, the suspension should be raised up to what is visually desirable for street use, making sure the wheels don’t rub against the fenders during cornering and also ensuring fender gap is equal on both sides. Show cars are usually not driven hard enough on the street to be concerned with correct weight distribution, so a simple visual inspection will usually suffice.
Old 01-29-2006, 02:59 AM
Blue04RedLine's Avatar
Originally Posted by bowtiess
lmmfao, h&r hasnt made them for your cars yet, i havent looked into it, if not HAHAHAHA. j/k that sux but im sure they will eventually
Yeah, "sure they will eventually" or "wasn't that supposed to be out last month?" are words we can LIVE by on the RL boards. H&R was supposed to be close to release of these springs for us in like November. They just keep stringing us along saying they'll be out shortly. Shortly has been 3 months and counting.
Haily229
09-17-2015 07:18 AM
breds2k
09-16-2015 02:07 PM
Josh@ottp
09-08-2015 10:18 AM
medic710
09-06-2015 08:53 PM
Quick Reply: GRAVANA LAUNCHES NEW H&R SPORT LOWERING SPRINGS FOR THE COBALT SS SUPERCHARGED COUPE!
