H&R 5x110 wheel spacers
Old Mar 25, 2013 | 08:17 PM
SS89's Avatar
Will this fit on a Cobalt SS/SC with stock 18" wheels and 225/45ZR18 tires?
Home Page > Search > 5x110 > ES#273 H&R DR Series Wheel Spacer - 15mm (1 Pair) - 3045650
I know I'll need extended studs as well which I found here
Extended Wheel Stud 22551491
Are there any other cheaper alternative for the studs?
edit : wrong section sorry
Old Mar 26, 2013 | 08:30 AM
SS89's Avatar
Nevermind, I don't think I'll have enough space between the tire and the fender. I will probably need to go with 5mm all around.
Old Mar 26, 2013 | 08:35 AM
mkulrey13's Avatar
1" adapters make the TC rims fluch with TCs. You have some supersized tires?
Old Mar 26, 2013 | 08:39 AM
SS89's Avatar
I have the stock SC rims, not TC ones. Are they the same?
Old Mar 26, 2013 | 08:47 AM
turbosmart4's Avatar
What do u mean?
Old Mar 26, 2013 | 09:03 AM
1" oughta make u flush but u also may be rubbing
Old Mar 26, 2013 | 09:21 AM
drumrush's Avatar
Arp 7708 studs should be cheaper
Old Mar 26, 2013 | 01:05 PM
SS89's Avatar
1 inch seems way too much, isn't the tire going to hit the fender as soon as you drive over a bump?
Old Mar 26, 2013 | 01:09 PM
forgot about this recent thread. lots of good similar info discussed in here
https://www.cobaltss.net/forums/gene...wheels-294125/
Old Mar 26, 2013 | 01:19 PM
EXsoccer1921's Avatar
no they won't fit. the centric ring on lsj/lnf hubs is 67.1mm that spacer has a centerbore or 65mm. won't fit on the hubs
Old Mar 26, 2013 | 01:22 PM
SS89's Avatar
Thank you for the link
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
