H&R or B&G ?
What's up, I'm really looking deep into what springs to buy for my 06 cobalt SS/SC . I have narrowed it down to B&G and H&R. I'm looking for a nice even / level drop while I am riding comfortably . All comments and pictured are appreciated , thanks !
I prefer H&R myself, but do NOT cut coils off the springs, they are progressive springs designed at a very specific spring rate to improve ride quality and performance. You throw that all out the window if you cut the spring down. This isnt honda-tech and most people dont subscribe to that kind of stupidity.
and cutting springs is not a big deal. I dont advise it, but its not the end of the world particularly with aftermarket springs that are not progressive.
ps cutting dead coils does nothing. well almost. helps the spring fall out over bumps at the rear...
progressive rate springs? Figures say not. the marketing hype says "progressive design\" bs
As you clearly dont know, and are quick to jump and tell folks they know know stuff, check this out: you have to compress a spring one inch prior to further compression of another inch when checking and measuring rate in a conventional spring rate checking device. ( google longacre) Dead coils compress immediately within one inch of travel; they are "dead".
next
O mi. I guess you dont understand the purpose of dead coils. Nothing to do with rate as such. They keep a shorter spring for low ride height from falling out when the suspension is in full rebound. dual rate? more bs.
next
next
I learned my lesson with lowering springs. I had CM springs on my old LSJ, they don't ride that bad but can't go fast on bad bumps or it'll slam hard. Also, I can't even drive the car during winter. This time I am going for Powell's YYZ.
CM springs ride OK, but you hit even the slightest imperfection in the road and you feel like the car is going to fall apart.
I'm much happier with my SS/TC struts / springs and Koni rear shocks.
I'll take ride and handling over looks any day of the week.
Honestly when I had CM springs on I didn't notice that, ride was nearly like stock was. On H&R Sports now and they feel a bit stiffer, especially in the rear. Always so tempted to buy some KW coilovers, but those bad boys cost a pretty penny.
I did as well....
lol KW those are like...2 grand a set i believe.
PA roads blow. That's the main problem, and why I hated ***** footing around in fear of hitting a hole or bump in the road.
lol cmon out to jersey this time of year, my friend hit a "pothole" a couple weeks ago and all of the side curtain airbags went off on his new VW lol
Your was always sexy as hell Metallic. My H&Rs never seemed to drop quite that low in the rear unfortunately. Hopefully a powell sway bar weights in down the in back slightly, haha.
