Hawk Front Pads for TC
Old Jan 5, 2011 | 11:29 PM
ronn's Avatar
Anyone have em on the front Brembos? How do ya like em?
Thanks...
Old Jan 6, 2011 | 01:06 AM
Wangspeed's Avatar
The stock ones are probably better than HPS, so unless your goal is to reduce dust with Hawk Ceramics, you won't find a performance gain. I'm running HPS in the back, and it's fine. Nothing to write home about.
Old Jan 6, 2011 | 01:11 AM
ronn's Avatar
Yeah..it was the dusting I was thinking about. Wondering if Hawks are about the same perf wise and just as quiet as stockers. I'm going to use them on the rear because they have the groove down the pad for clearing out debris.
Old Jan 6, 2011 | 01:21 AM
09sscalicobalt's Avatar
i heard the stocks are the best out there im stock pads and rotors and they worked just fine in november at fontana
Old Jan 6, 2011 | 01:46 AM
Wangspeed's Avatar
The stock are pretty good, but you cant beat a full race pad for the track.
Old Jan 6, 2011 | 11:39 PM
Stamina's Avatar
I'm installing some HPS pads along with some R1 rotors this weekend hopefully. I can report back after I properly bed and break them in. I love the stock pads and wouldn't think twice about changing if it wasn't for the dust.
You may see me going back to stock pads or another pad if it doesn't work well. Hopefully the HPS can handle light track use.
Old Jan 6, 2011 | 11:42 PM
ronn's Avatar
Sounds like a plan. Thanks.
Old Jan 7, 2011 | 12:26 AM
Wangspeed's Avatar
HPS are just as dusty as stock. Hawk Ceramics would be slightly less.
Old Jan 7, 2011 | 06:12 PM
ronn's Avatar
If that's the case I'll stay with stockers.
Old Jan 7, 2011 | 06:32 PM
BlackLsCoupe's Avatar
suck at stopping when wet. have hawks in front with some semi metalics in rear, needing to redo them since its eather alot of grind in rear or car seems like it wont stop. other wise in autocross they did fine to me since i go into turns hot
Old Jan 7, 2011 | 07:14 PM
Stamina's Avatar
Yeah, I already have HPS on the back and they've been doing wonderful as far as dust, but those aren't really comparable to having them on the fronts, so it's hard to tell what it'll be like.
Old Jan 7, 2011 | 07:19 PM
gotboost?17's Avatar
Nothin Stock
sub'd for later
Turbalt2010's Avatar
sub'd id like to know the results lol
Old Jan 7, 2011 | 07:50 PM
SSSnoop's Avatar
Stockers bind well, but what the heck with the squealing? If I don't drive my SS/TC for 3 days, I have to deal with sounding like a dump truck howling to a stop.
If I drive ice cold with little breaking, I set the neighborhood dogs barking with the two sopranos hitting their notes from my front wheels. It seriously makes me want to pound the brakes hard several times just to heat them up to the point where they howl less.
I was thinking of going aftermarket just to reduce this - and I tried a little Disc Brake Quiet on the pads, but either I didn't do enough, or its the pads.
Am I the only one with the stock screaming pads?
Old Jan 7, 2011 | 10:21 PM
ronn's Avatar
FRONTS?? We know the rears can act up, but the fronts are dead quiet. My rear stockers have always remained quiet as well. Check to see that your front pads are actually stock.
Old Jan 7, 2011 | 10:31 PM
we dont have to drive in the snow and extreme cold tho ronn like he does when my car is cold and i havent driven much it brakes like **** too
Old Jan 7, 2011 | 10:48 PM
jboogie's Avatar
Mine squeeled like crazy until my first track day at 3k miles. Gotta bed them in.
Old Jan 7, 2011 | 10:50 PM
black67's Avatar
I have the Hawk HPS pads in the front and rear of my 09 SS. They work great. They act very similar to the Brembo pads, but with a lot less dust. The Brembo pads would cover my wheels a week, the HPS pads put the same dust out in a month. When its cold out, like it has been today (18°F) they will squeak just a bit till they get some heat in them. When they are wet, at first they have little grab. Once the water is moved off the rotor, they work good. The Brembo's acted the same way when cold and wet. They work great with some heat in them, so in the winter they are a bit fun at first. I have not put my car on the track, so I can not tell you how they act there. I do know a race pad would be better, but my car is a daily driver, so I did not go with the race pad.
My rear brakes destroyed the inner pads and the rotors. This then caused the fronts to go, warped really bad. So I replaced all the pads with Hawk HPS and rotors from R1 Concepts. So far, not problems with them.
My factory front Brembo's would squeal every once in a while. Once I gave them a good hard hit, they would be good for about a week or so.
Last winter I had a problem with the brakes. I would hit the pedal, and it would go to the floor. This happened a few times. The dealership could not find anything wrong, bled the brakes and it still did it. Ok, I do live in a cold area and get snow, but that sucked. Now, I have not seen this problem all winter since I did the brake job.
I have had HPS pads on a few cars and my truck. On my truck, they were the best pads for it. They lasted 100k miles until I had a caliper stick. Very little dust on this also.
Old Jan 7, 2011 | 10:53 PM
TommyP's Avatar
AWD > FWD
I'd say the stockers stop better, but they put out WAY too much brake dust. These aren't as strong, but give off almost no dust. Just gotta choose which you prefer. To me, these are a great replacement for stock. If you're gonna be doing some track days, I'd probably stick with stock. However these will be just fine for the street.
Old Jan 7, 2011 | 11:20 PM
ronn's Avatar
Ok..we have TWO here so far that have em on and vouch that they dust MUCH less. I don't track the car, so it looks like HPS all around for me..
The fu$$kn dust is really a pain for me
Appreciate the feedback.
Old Jan 7, 2011 | 11:24 PM
boo why dont you ever track is ronn we went out to fontana in november and had a blast its coming up again in april or may and in feb speedventures is gonna be at willow springs
Old Jan 8, 2011 | 12:42 AM
Wangspeed's Avatar
If you want to reduce the dust, just get Hawk ceramics. If you're just street driving, you won't notice the degrade in performance.
Old Jan 8, 2011 | 01:17 AM
Malaclypse's Avatar
You aren't the only one. Mine squeal so bad its rediculous...
Maybe I should do what was suggested in this thread and go bed them. Lets see if I can boil the brake fluid.... =p
Old Jan 8, 2011 | 05:07 AM
ronn's Avatar
Just posted this on another thread talking about DUST:
https://www.cobaltss.net/forums/5484986-post11.html
Old Jan 8, 2011 | 08:34 AM
07SSYellow's Avatar
Resident Post Whore/Troll
the brake dust doesnt bother me, i dont mind taking a cloth to the rims every few days haha i dont track my car though so thats probably why, and im gonna powdercoat my wheels charcoal grey so it will "blend in more" problem solved haha
