hawks pads
If you crack the bleeders on the calipers to push the pistons back in, then yes. You can also just squeeze the pistons back in, on a new enough car that is usually fine and done all the time. If you do that, therefore not opening the system, you don't have to bleed it.
Bleeding brakes is not very hard, are you worried about it?
Then just squeeze them back in. Fronts are simple, rears should be turned in, I have the tool for it, or they sell them at autozone and places like that.
It like $8 at the parts store. Check it out.
