Help! I want a mean suspension!
Old May 22, 2013 | 02:29 PM
BLK05SS's Avatar
Can anybody help me out? I need advice on EVERYTHING I will need for a completely badass suspension. I have read the suspension 101 sticky thread. I'm willing to spend some good money on it. I just need advice cause I'm pretty new with cars. I don't care a whole lot about ride comfortability. Performance is most important to me. Thanks in advance for your help guys.
Old May 22, 2013 | 02:32 PM
LS6Rally's Avatar
What are you doing with the car? What model Cobalt do you have?
Old May 22, 2013 | 02:33 PM
Sox-Fan's Avatar
Got Brakes?
Hi
Start here.
https://www.cobaltss.net/forums/gene...powell-296456/
Old May 22, 2013 | 02:49 PM
BLK05SS's Avatar
Its a daily driver, I just want to make it perform much better and give it some new life. Its a 2.0 SC.
Old May 22, 2013 | 02:51 PM
nobody2u's Avatar
Two words: Koni, Powell
Old May 22, 2013 | 03:08 PM
xriverrat's Avatar
Originally Posted by Sox-Fan
x2
Old May 22, 2013 | 03:18 PM
yellowsupercharged06's Avatar
send John a blank check and tell him to hook u up lol
Old May 22, 2013 | 03:19 PM
breds2k's Avatar
Powell hardcore bar, powell v2 springs and konis all around DONE!
Old May 22, 2013 | 03:22 PM
Sox-Fan's Avatar
Got Brakes?
lcabs before anything. Seriously. After doing mine the first thought was that I'd wished I'd done it first. Then the bar, then the springs and shocks.
Old May 22, 2013 | 03:23 PM
BLK05SS's Avatar
Thanks for the help guys!
Old May 22, 2013 | 03:29 PM
Omiotek's Avatar
heres my 2 cents... powell makes the best suspensionstuff out for this car.
powell hardcore bar(xxx if u plan on more track time)
konis and yyz v2s
hardcore control arms(at minimum the spherical lcabs
twisitng beam bushings
that should be give you a good start
Old May 22, 2013 | 04:53 PM
LS6Rally's Avatar
^this!
Trying to save up for his spherical cabs, and rotated mounts (F23)
I have the YYZ v.2's with koni yellows, and the Hardcore rear bar . man this thing handles like its on rails. I hear the cabs should take any play out and increase the steering response. It's next on my list, i need to do brakes anyway.
If you can do what the others have suggested with Powell you will fall in love with your car again.
Old May 22, 2013 | 05:07 PM
breds2k's Avatar
do his CAB's really make THAT much of a difference? Just better steering feel I thought.
Old May 22, 2013 | 05:12 PM
Sox-Fan's Avatar
Got Brakes?
Where does steering feel come from, Bob? Think on that.
It makes the front end suspension components travel in truer arcs and with less friction. That translates to better tire wear, better ride, better handling, all of those things. Is the steering wheel tighter? Sure. But instead of transferring the pounding of bumps to the chassis it lets the suspension do the work of absorbing them as was designed. Better ride. Better tire wear because the suspension holds the alignment through it's travel.
win win.
Old May 22, 2013 | 05:22 PM
breds2k's Avatar
good deal and honestly, I just remember or thought i remember someone saying that. Im stuck at work for 2 hours late on some ******* that may/may not show up and ive got a head cold FML.
Old May 22, 2013 | 05:31 PM
Sox-Fan's Avatar
Got Brakes?
Well, I hope he shows for your sake.
Old May 22, 2013 | 05:40 PM
Verbatim's Avatar
as others have said...
drop car off at powell with blank check; you will get the best
Old May 22, 2013 | 05:57 PM
m33pm33p's Avatar
Replace your shocks with 2x4's and you will deffinitely have a mean suspension.
Old May 22, 2013 | 06:04 PM
Omiotek's Avatar
i see what hes saying.... it doesnt make the steering itself better but however when your going into a corner hard you definatelly feel the arms respond to the motion of steering which is honestly my favorite part about it. the front end REALLY bites.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
