help quick
Old Apr 19, 2010 | 12:25 PM
BumbleBee's Avatar
Exclamation help quick
I cant seem to get this bolt out, I have the nut off.
and mine is a lot less pretty, rusty and corroded. is it threaded all the way through or not?
Old Apr 19, 2010 | 12:28 PM
BlackJackSS's Avatar
rubber hammer. or it should come out if you impact it out from the screw head.
Old Apr 19, 2010 | 12:32 PM
BumbleBee's Avatar
the bolt head will not fit a socket, only 2 flat edges.
Old Apr 19, 2010 | 12:33 PM
kevinj4891's Avatar
use a jack and lightly lift up the disc brake and take tension of of it
Old Apr 19, 2010 | 01:01 PM
BumbleBee's Avatar
tried that, so its not threaded through the whole thing?
bump, need help from peeps who have installed lowering springs
Old Apr 19, 2010 | 01:08 PM
06cobalt racer's Avatar
nope what i did was take the nut off flip the nut over screw it back on till it is flush with the bolt. then hammer away!!
Old Apr 19, 2010 | 01:12 PM
ItalianJoe1's Avatar
This.
Put the nut back on it and hammer it out. The end of the bolt is actually tapered pretty good, you can hit it direct with a hammer if you are careful, but the safe bet is to just thread the nut back on a little.
Old Apr 19, 2010 | 01:13 PM
TommyP's Avatar
AWD > FWD
I think I used a hammer + blunt chisel. Idk I remember hammering it out though.
Old Apr 19, 2010 | 02:23 PM
use the hammer. i think you would be suprised on how much a hammer is actually used when working on cars. so dont be affraid of it. HIT IT LIKE YOUR MAD AT IT!
Old Apr 19, 2010 | 02:32 PM
exiged's Avatar
x3. on the hammer.
Old Apr 19, 2010 | 02:40 PM
ilovecars's Avatar
put the nut back on slightly so you dont damage the threads. then hammer. its ok its pressed in.
Old Apr 19, 2010 | 07:07 PM
Nighthawk243's Avatar
A big hammer is one of the handiest tools for car work...
Percussive maintenance FTW.
Old Apr 19, 2010 | 07:11 PM
ecot3c inside's Avatar
hammer it, but make sure you don't mushroom the end of the bolt otherwise you can't get the nut back on . so. x3 on the hammer.
Old Apr 19, 2010 | 10:38 PM
BumbleBee's Avatar
thanks for the help guys, a lot of hammer time worked, although I hope my springs settle a little more. A little disappointed in the sportlines drop but it looks better
Old Apr 19, 2010 | 10:41 PM
oowah's Avatar
I felt the same way when I put my sportlines on (not sure what cobalt you have...) but after a week they settled quite a bit more. Still not slammed, but I think it's a good drop while staying practical
Old Apr 19, 2010 | 11:03 PM
BumbleBee's Avatar
ss/sc. im going wingless so I thought there would be a little more drop but i like it.
Old Apr 20, 2010 | 02:36 AM
now you should get an alignment done.
Old Apr 21, 2010 | 12:33 PM
kevinj4891's Avatar
like the saying goes:
if at first you dont succeed, use a BIGGER hammer...
ya, stupid like a fox
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
The Rookie24
Sep 20, 2015 04:33 PM
toledobalt
Sep 2, 2015 01:19 PM
