Help with Rear Suspension.
Old May 20, 2011 | 03:52 PM
DOMDOTCOM's Avatar
MADE STANCE COOL
Is there anyway i can make the rear stiffer, other then buying new rear springs? The spring rate on my Ksports are 4kg in the rear an thats wayy to soft. any suggestions?
Old May 20, 2011 | 03:53 PM
DiabeticKripple's Avatar
sway bar
Old May 20, 2011 | 04:02 PM
ls1fbody's Avatar
Haz l33t wheelz.
springs, thats the only way.
Originally Posted by DiabeticKripple
sway bar
not for what he's talking about haha
Old May 20, 2011 | 04:04 PM
DOMDOTCOM's Avatar
MADE STANCE COOL
aww shitty. who should i email?
Old May 20, 2011 | 04:34 PM
ls1fbody's Avatar
Haz l33t wheelz.
ksport. I dunno if they offer replacements, but it wouldn't hurt to try.
Old May 20, 2011 | 09:49 PM
ronn's Avatar
4KG is about the rate stock for TC..a tad less actually.
They should be stiffer than your current fronts..which are?
4 (kg / mm) = 223.989658 pounds / in
5 (kg / mm) = 279.987073 pounds / in
6 (kg / mm) = 335.984488 pounds / in
7 (kg / mm) = 391.981902 pounds / in
8 (kg / mm) = 447.979317 pounds / in
EDITED:
Found the rates for your set up. Rears should be at least the same as fronts. I see a lot of people go with 6KG/6KG in other set ups here.
KSPORTS
Chevrolet Cobalt - 2005 - 2010 - CCV040-KP 1600 (F)7.5KG/420LB (R)4KG/224LB
Old May 20, 2011 | 09:53 PM
HB_SS/TC's Avatar
Footballs
Old May 20, 2011 | 11:34 PM
scottherbert's Avatar
Get a sway bar! It'll be a huge change in the way the car handles (particilarly roll) without making the suspension so hard you can't stand it.
Scott
Old May 20, 2011 | 11:38 PM
thedude411's Avatar
he probably needs it for stance reasons to make sure he doesnt rub and **** on bumps?
Old May 21, 2011 | 12:40 AM
seeyaass's Avatar
Originally Posted by hb_ss/tc
footballs
+1
Old May 21, 2011 | 01:35 AM
jboogie's Avatar
Problem solved
Old May 21, 2011 | 01:43 AM
jboogie's Avatar
you know stock spring rates??
Old May 21, 2011 | 01:46 AM
ronn's Avatar
Stock rates are 154 lbs (linear) front and 160-228lbs rear (Prog).
Old May 21, 2011 | 09:21 AM
jboogie's Avatar
Thank you sir!
Old May 22, 2011 | 05:11 PM
05vue-redline-06ion's Avatar
Eibachs are stiff as hell
Old May 22, 2011 | 05:17 PM
MP Cobalt's Avatar
Dom i got it. sell my your coilovers and buy my springs and struts
Old May 22, 2011 | 05:19 PM
whyyoumadson?'s Avatar
this dude DOES NOT need a rear sway bar...you wanna explain to me how the hell a sway bars going to help him stiffen strut and spring compression lol!!!!!!!!!!
dom your best bet is different spring rates, footballs(literally a football in the rear springs, or drag bags.
not really. probablly stiffer then those k sports though.
Last edited by whyyoumadson?; May 22, 2011 at 05:19 PM. Reason: Automerged Doublepost
Old May 22, 2011 | 05:23 PM
TommyP's Avatar
AWD > FWD
I love people who don't read threads. How is a sway bar supposed to make the rear stiffer in the same way a set of springs would? I agree with above, footballs would probably be a good cheap solution without buying a set of springs.
Old May 22, 2011 | 05:28 PM
09sscalicobalt's Avatar
yea but footballs is also gonna raise the car up and he doesnt really want that lol
Old May 22, 2011 | 05:30 PM
not neccisarily. drag bags would do that more because they usually repalce the entire spring. footballs you can pump air in and out just like a drag bag. personally dude you just need to pony up the cash and get springs because those 4k springs are bs.
Old May 22, 2011 | 05:32 PM
haha he told me yest he talked to ksport and they can make them in whatever k he wants
Old May 22, 2011 | 05:38 PM
DOMDOTCOM's Avatar
MADE STANCE COOL
nah i talked to Ksport i am getting my new springs before wekfest
Old May 22, 2011 | 07:45 PM
qwikredline's Avatar
ronn here is what I measured on my spring tester. TC front
comp.ht. rate in lbs
11 in 150
10 in 280
9 in 450
8 in 620
7 in 750
TC rear
11 100
10.5 in 150
10.0 in 180
9 330
8.00 in 460
Ya I got practically all springs measured....not gonna post tho'
Old May 22, 2011 | 07:51 PM
haha and this is why we trust your opinion john!
Old May 22, 2011 | 07:52 PM
jboogie's Avatar
11 in 150
10 in 280
9 in 450
8 in 620
7 in 750
TC rear
11 100
10.5 in 150
10.0 in 180
9 330
8.00 in 460
always tease me with those Pedders rates! lol all good though, I understand. One day when I feel like tking them off and driving to Charlotte I'll measure them.
