Help with Rear Suspension.
Thanks for the info!
FRONT>>>27N/mm is 154 lb/in... linear
REAR>>>28-40N/mm is 160-228 Lb/in... progressive
2008 Chevrolet Cobalt SS Turbo 2.0 L Ecotec Turbocharged 260 hp | Prices, Reviews, Specifications
The MacPherson strut independent front suspension uses SS-specific gas-charged twin-tube struts; unique steering knuckles with optimized geometry; 27 N/mm linear coil springs with specific damper tuning; stiffer control arm handling and stabilizer bar bushings; and a direct-acting, 24-mm solid stabilizer bar. At the rear, the SSs semi-trailing twist beam axle uses monotube gas-charged shocks with specific damper tuning, a 24-mm solid stabilizer bar, stiffer axle bushings and multi-rate coil springs (28-40 N/mm).
Thanks..how do you explain those #s with the published rates here?
The MacPherson strut independent front suspension uses SS-specific gas-charged twin-tube struts; unique steering knuckles with optimized geometry; 27 N/mm linear coil springs with specific damper tuning; stiffer control arm handling and stabilizer bar bushings; and a direct-acting, 24-mm solid stabilizer bar. At the rear, the SS’s semi-trailing twist beam axle uses monotube gas-charged shocks with specific damper tuning, a 24-mm solid stabilizer bar, stiffer axle bushings and multi-rate coil springs (28-40 N/mm).
but your quoted source says 27 N/mm or newton millimeters. so I am assuming its all bs crap....
dunno who distro cars are...the "unique steering knuckles" is bs,like what is unique about them? same knuckle over 5 years just a little stronger and shorter steering arm, hardly unique...so... they says 27 n/m = 239 lbs inch.
Here is another link same info
Officially Official: 2008 Chevy Cobalt SS Turbo with 260 HP bows at SEMA — Autoblog
Same identical wording N/mm..not N/M. Is this a typo then?
The MacPherson strut independent front suspension uses SS-specific gas-charged twin-tube struts; unique steering knuckles with optimized geometry; 27 N/mm linear coil springs with specific damper tuning; stiffer control arm handling and stabilizer bar bushings; and a direct-acting, 24-mm solid stabilizer bar. At the rear, the SS's semi-trailing twist beam axle uses monotube gas-charged shocks with specific damper tuning, a 24-mm solid stabilizer bar, stiffer axle bushings and multi-rate coil springs (28-40 N/mm). StabiliTrak electronic stability control and traction control are standard.
Edited new info:
Here an old post by YOU!
https://www.cobaltss.net/forums/4041388-post9.html
Front Spring
Main rate = 177 lb/in (31 N/mm)
Initial rate (installed) = 143 lb/in (25 N/mm)
Free length = 282mm
Rate transition length = 173mm
Installed length = 148mm @ 3500 N
Rear Spring
Main rate = 126 lb/in (22 N/mm)
Initial rate (installed) = 63 lb/in (11 N/mm)
Free length = 306mm
Rate transition length = 179mm
Installed length = 154mm @ 1950 N
EDITED: The above rates are Eibach Prokit rates..not stock TC
Actually that info is from the original press release...
Front Spring
Free length = 282mm
Rear Spring
Free length = 306mm
Front Spring
Free length = 282mm
Rear Spring
Free length = 306mm
And since when was the press a reliable source of ANYTHING?
Also note that he uses N/mm here..not N/M. The question is are the stockers rated at 27
N/mm or N/M?
will is right I was quoting the eibach info. google for a conversion table. I am not sure what all this is leading to, I am out of it lol
.Here is an online converter.
Unit of Measure Converter
Just plug in 27 and below select n/mm (or n/m) in the pull down tab. Click *SUBMIT*. Then look at the equivalent values below...at Lbs/in.
Cobalt TC:
F: 27n/mm=154 lb/in Linear
R: 28-40n/mm= 160-238 lb/in Prog
From Press release on HHR..same units of measure..n/mm. Values are slightly different all around though.
F: 28 N/mm=160 lb/in LINEAR
R: 30/N/mm-40Nmm= 171 lb/in-238 lb/in Prog
The MacPherson strut independent front suspension uses SS-specific gas-charged twin-tube struts, unique steering knuckles with optimized geometry, 28 N/mm linear coil springs with specific damper tuning, stiffer control arm handling and stabilizer bar bushings, and a direct-acting, 23-mm solid stabilizer bar. At the rear, the SSs semi-trailing twist beam axle uses monotube gas-charged shocks with specific damper tuning, a 24-mm solid stabilizer bar, stiffer axle bushings and multi-rate coil springs (30-40 N/mm). StabiliTrak electronic stability control and traction control are standard
So, it seems like n/mm value is consistent with both reports. Again, are these reports from the press releases incorrect? Why would they be?
i ordered 5mm spacers for hte front lol
the answer to your question OP is select the rate you wish, based on the information here. Measure the length of your existing spring. Measure the inside diameter of your existing spring. Lets say you decide that 325 lbs linear is what you want. Lets suggest they are a 6 inch long x 2.25 i.d spring. Go to the Hypercoil web site and order your springs they will cost you about 75 dollars each . NP.
ur welcome.
ur welcome.
18x 9.5 right? I'm assuming around a +30-35 offset?
