HELP! Steering Messed Up!
Old Jan 12, 2010 | 01:58 AM
JsavageSS/TC's Avatar
So last week I was at work... I left my ex (whom still lives with my...fucked up situation...dont ask) the balt because she didn't go to work till after I had to. It had been snowin all day and my ******* didn't think about her knowledge in driving in snow.
Anyways, she hit curb....
Damage....
Driver/front steering and supension
Warped and scraped wheel
steering is ungodly screwed...
when I drove it home I noticed that i couldn't keep the car straight, it kept pulling either left or right.... the wheel was maybe turned 3 inches to the left and Iwas going straight.
I got home and pulled it into the garage, turned the heater on and waited for all the ice to melt off my car and then looked around... The passenger/front wheel was straight as it would normaly be, but the driver side was turned left slightly...
I need help because I jacked it up, looked under it and saw that the steering linkage, knuckles and all that where in tack, looked normal... I have no clue what it will be. I would like some really ood ideas before I have it towed off so maybe I can fix it myself and only have to worry about a new wheel and getting the alignement corrected
thanks ahead of time
Bump!
Last edited by JsavageSS/TC; Jan 12, 2010 at 01:58 AM. Reason: Automerged Doublepost
Old Jan 12, 2010 | 02:25 AM
outtamymind's Avatar
your toe is out. go and get an alignment done and they can also tell you while doing that if anything is bent that you can not see. and the alignment will fix the steering issue if nothing is truely bent.
Old Jan 12, 2010 | 02:59 AM
Maven's Avatar
If your steering wheel is 3" to the left when going straight **** is bent
Its most likely the tie rod got bent. it could be other things but yeah you need to get it checked out.
Old Jan 12, 2010 | 04:53 AM
Damnit Maven... the truth hurts
I am definatly getting to a shop asap, is there any way that I can tell myself if the tie rod is bent? I hope the contorl arm isn't....
Thanks guys
here are some pics if it will help aswell....
thanks again
Old Jan 12, 2010 | 05:21 AM
Bades's Avatar
honestly its hard to tell if sumthing is bent unless its painfully obvious with out the use of an alignment machine...there are a number of things that could causethis after hitting a curb just hope ur alignment is out lol
Old Jan 12, 2010 | 02:10 PM
ya from those pics it doesn't look like your tie rods are bent. but the only way to know for sure is to get it checked at a shop
Old Jan 12, 2010 | 07:23 PM
qwikredline's Avatar
rack or knuckle or both; the tie rod maybe bent under the boot at the pivot...either way not cheap...sorry...
Old Jan 12, 2010 | 07:28 PM
JapEatr's Avatar
South Central *********
my guess is lower control arm is bent! THEY ARE EASY TO TWEAK!!
Old Jan 13, 2010 | 12:36 AM
Well I do know now that the lower control arm is jacked....
damage to wheel...
Lucky me, I know a dealer who knows a service tech who is going to hook me up... Now I just need to know exactly what I will need...
Wheels (found scrapes on rear wheel too)
lower control arm
ball joint
spindle maybe?
Old Jan 13, 2010 | 12:58 AM
Maven's Avatar
control arm comes with ball joint
Old Jan 13, 2010 | 01:03 AM
ls1fbody's Avatar
Haz l33t wheelz.
we don't have a spindle. Try doing the control arm first, yours is all kinds of fuggered up
Also, i wasnt aware the NT555 was marketed as a snow tire...
Old Jan 13, 2010 | 01:05 AM
scoshus99999's Avatar
control arm is fuged up. id also check to make sure your frame is straight. my friend hit a curb one winter square with the wheel and bent his frame.
Old Jan 13, 2010 | 01:16 PM
How is it marked as a snow tire?
Old Jan 13, 2010 | 01:36 PM
Maven's Avatar
its not....he said he didnt know that it was....it was sarcasm because he knows that the 555 is a summer only tire, and should have never been in the snow. If this is insurance related they may not pay..........
Old Jan 13, 2010 | 02:57 PM
Terminator2's Avatar
Those will turn to stone at anything below 50*. Defintely a very poor choice for cold weather let alone snow and ice.
Do you mean he bent his unit body? Unless he had a really old car or a pickup his vehicle had no frame. Bending a unit body from striking a curb must take a brutal impact to accomplish.
Last edited by Terminator2; Jan 13, 2010 at 02:57 PM. Reason: Automerged Doublepost
Old Jan 13, 2010 | 04:19 PM
JapEatr's Avatar
damage to wheel...
lower control arm
ball joint
spindle maybe?
nailed it...just put a new FE5 arm on it and get it realigned
FYI those arms are only 150 at crateengine depot
Old Jan 13, 2010 | 07:33 PM
Thanks guys!
I know they are not marked for winter or snow.... I just didn't catch the sarcasm and thought maybe he thought they were snow tires...lol
The 555's actually grip pretty well in the winter and this is my second winter with them on there. First winter was nothing but ice and I have never had the the money to put winter shoes on it.
I know I need to replace the control arm and I know it needs to be aligned after that.... but I had to take my ex to work today because she didn't have any other way there. The ESC flashed and the DIC says Service ESC... Is there a sensor somewhere in the suspension that needs to be replaced or is this something that will correct itself once everything is fixed?
Old Jan 13, 2010 | 08:30 PM
ls1fbody's Avatar
Haz l33t wheelz.
your car is pissed at you because your toe is all fucked up, as well as your camber. You're essentially snowplowing that tire, and the ESC is fighting to figure out what's going on.
Don't drive it until you get it fixed.
Old Jan 13, 2010 | 08:55 PM
Maven's Avatar
The car knows its going straight with the wheel turned, so its figured out that something is broken.
Youre a more forgiving man than me.....My EX still lives with me(strike 1) my ex has to drive my car(strike 2) my ex crashes my car in the snow (strike 3) My ex makes me drive her to work (strike 4.....wait thats too many) That scenario just wouldnt have gone down out here, LOL. Hope you got reallllllly good reasons for letting this happen.
Old Jan 13, 2010 | 09:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
yeah, like she's covering the damage with giving head, and she better be SMOKING hot.
Solaris99
28
Mar 15, 2017 01:22 PM
no_ss
Oct 18, 2015 11:58 PM
TedSS
26
Oct 10, 2015 04:30 PM
Iceberg
Sep 28, 2015 01:31 PM
jmelton327
Sep 26, 2015 10:04 PM
