Homemade rear sway bar?
Old Nov 30, 2012 | 11:02 PM
Pitbull2o08's Avatar
being the broke college student that I am, I've been wanting to upgrade my suspension, but can't I've been looking at a lot of rear sway bars in the classifieds, and they all look like just bent 1" bars with holes for bolts. I tried searching, and couldn't find any threads on people trying to make them. I bet if you wanted to, you can get a solid 1" pipe, instead of a hollow one and bend it to spec. Has anyone tried this? It'd be something I'm interested in sice I can't shell out a couple hundred for a bent bar.
Old Nov 30, 2012 | 11:05 PM
Sox-Fan's Avatar
Got Brakes?
Solid?
Oh, and just how are you going to bend a solid 1 inch bar?
Not trying to kill your dreams, but this idea is more difficult than it is worth.
Old Nov 30, 2012 | 11:07 PM
With a hydraulic pipe bender.
Old Nov 30, 2012 | 11:08 PM
F_Imports_09tc's Avatar
Could you do it, sure anything can be done. Do you have the equipment bend the bar? Do you have access to a welder, drill press, etc?
You need spring steel though, not the stuff you get at your local welding/metal supply place. In the end buying one is probably not much more than making one.
Old Nov 30, 2012 | 11:11 PM
Sox-Fan's Avatar
Got Brakes?
If you do have access to a hydraulic pipe bender that actually can bend 1 inch solid bar you're going to have something that weighs 125 pounds and doesn't flex.
If you use something not solid but the wrong materiel it'll flex. Sure.
Once.
If you don't know or understand the engineering involved before you embark on this endeavor you're going to spend far more than the sway bar costs to buy and potentially place yourself and others at risk.
Old Nov 30, 2012 | 11:12 PM
Yeah I have access to a hydraulic pipe bender, welder and drill press. I just have to find out what kind of steel is used. I don't care if I use solid steel. Just making one and learning will be worth it. I'm sure I won't spend close to $200 doing it so it'll be a win/win
Old Nov 30, 2012 | 11:13 PM
Solid steel won't work. It'll yield. You need spring steel.
Old Nov 30, 2012 | 11:16 PM
Sox-Fan's Avatar
Got Brakes?
I hate hate hate discouraging people from trying to learn new things so I'll stop here and just advise extreme caution. Good luck.
Old Nov 30, 2012 | 11:20 PM
Thanks. I appreciate constructive feedback though. I just can't believe no one has tried this. My best friend is a mechanical engineer and we would build things all the time for our cars growing up.
Old Dec 1, 2012 | 01:26 AM
Nfamous60's Avatar
in for finished product
Old Dec 1, 2012 | 01:41 AM
Vander Nars's Avatar
in for moar lolololols
Old Dec 1, 2012 | 08:02 AM
Wangspeed's Avatar
All the information you need has already been posted here by John Powell.
Old Dec 1, 2012 | 08:32 AM
theamericanautos's Avatar
very interesting. subd for finished piece
Old Dec 1, 2012 | 08:34 AM
BoostedBeaner's Avatar
Buy Powell race parts. /thread
Old Dec 1, 2012 | 11:33 AM
Omnigear's Avatar
nga is broke so he is makin one
Old Dec 1, 2012 | 11:35 AM
Sh3itskees's Avatar
OP already stated he can't afford it. At the same time though, there's NO WAY I would make a component for my suspension like that unless I had a very very high degree of confidence in the person who made the part. I would hate to see what would happen if the bar wasn't strong enough and broke under load, that would probably be pretty messy... Good luck though, and definitely be safe!
Old Dec 1, 2012 | 11:40 AM
I understand that the op said he was a broke college student. So if you know your broke then don't expect to mod your dd. it's idiotic. Unsafe when making homemade custom suspension parts. If you are broke then where are you using your parts? School?
Old Dec 1, 2012 | 12:11 PM
sLAsh's Avatar
No reason you can't make one if you have access to the right materials, right tools, proper skills and the engineering. IMHO it doesn't make much sense unless you have an application that doesnt have an aftermarket version available. Doubt it would save you much if any money in the end.
Here is a homemade one for a Honda fit.
DIY rear sway bar - Unofficial Honda FIT Forums
Another option would be to locate a bar in the junkyard that looks close and mod that. In any case watch the heat when you are welding so you don't take the temper out of the spring steel otherwise you will put it on and it will twist like a licorice the first time you put any force on it.
Old Dec 1, 2012 | 12:25 PM
Maybe you're all right. I was just curious if anyone's ever done it. I don't really have any time right now anyways d/t school.
Old Dec 1, 2012 | 12:33 PM
emiller's Avatar
Could be an interesting project but bend it wrong or use the wrong material and it wont work in a possibly very bad way.
Old Dec 1, 2012 | 01:03 PM
CobaltSS89's Avatar
In for moar of his post, makes me laugh
Old Dec 1, 2012 | 01:04 PM
LS6Rally's Avatar
^ this or when it snaps while its under load in a turn....
Like Sox-Fan i like seeing people come up with new things, but suspension stuff and an Ice box for the top of your blower are two different things.
just be careful
Old Dec 1, 2012 | 01:06 PM
LS6Rally's Avatar
Progress Rear Anti Roll Sway Bar 05 09 Chevy Cobalt | eBay
Old Dec 1, 2012 | 01:07 PM
LS6Rally's Avatar
or this
Eibach Anti Roll Single Sway Bar Kit Rear Sway Bar Only Part 3899 312 | eBay
Old Dec 1, 2012 | 02:00 PM
Sh3itskees's Avatar
This is more or less what I was getting at lol.
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
