how do i lower rear coilovers?
The rear you have to turn the dial under the spring because its not independent from a shock.
Messing with the dial in the front changes the preload and if its set from the factory changing it can make it ride really rough and cause the shock to bottom out. That can cause the shock to fail so just lower and raise it with the lower mount.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
