how low and stiff are you
Old Mar 15, 2013 | 12:30 PM
mufinman007's Avatar
Question how low and stiff are you
i got my stance about a month ago and just slapped them on . Went as low as i could with out taking lock out rings loved the way it looked but rode like ass. Took the wheels off and noticed rubbing so decided i would raise it . After i did i noticed the adjustments where way off drivers right was 16 ( 16 being the stiffest and 1 being the softest on Stance coilovers) and the rear was 1 well I decided to read the manual and figure out how to adjust it . I set them all at 8 still had to much bounce stiffing up the back to 12 and left the front at 8 made difference but i wanted to know what 12 felt like all the way around (my current set up now) still got that bounce this time feels like the front . i am getting my rims painted this weekend and will have the car on jack stands so gives me time to mess with the adjustment again any suggestions would be great on your set up (dont have to be stance to have a opinion) first pic should be when i first had them put . again maxed out as low and not adjusted and rode like ass and the second one should be raised and adjusted at 12 all away around
Old Mar 15, 2013 | 12:41 PM
07cobaltLScoupe's Avatar
do you mean bounce as like it pogo's and just keeps hoping over bumps and doesn't settle down? from what i've been hearing Stance seems to have a little too low of a spring rate in the rear so you may have to stiffen up the rear strut all the way if it's too soft for you. i'm on Megan Racing coilovers all the way down (lock rings still installed) with my settings at about 24/32 front and rear and it's not too bad, if anything that may be a little stiff
Old Mar 15, 2013 | 12:45 PM
EMAC X 61's Avatar
let me know when you get it figured out to a good setting because i have stance coils also havent installed them, but i dont want my car bouncing around all over the place!
Old Mar 15, 2013 | 12:52 PM
bounce as in pogo after a few bounces it stops until i hit another bump . buddy of mine told me to adjust the shock . mind you i am a noob and learning this on trial and error i raised the car by compressing the the spring but i am sure thats why it bounces since i am shorting the spring and not giving it room to compress
Old Mar 15, 2013 | 12:57 PM
Omiotek's Avatar
the stance coilovers have low rates in the rear... thats one problem.... the other problem is its a coilover... they will never ride good. meaning they will always have a harsh ride for the most part but you should be able to get it where its tolerable.
Old Mar 15, 2013 | 01:00 PM
^ what he said, but it also sounds like you need to adjust the pre-load on the rear shock
Old Mar 15, 2013 | 01:02 PM
would i be doing that by adjusting the damping ?
Old Mar 15, 2013 | 01:03 PM
u need to pre load the shocks in the rear
pretty much adjust the length of the shocks and the damper to your liking
bolt the top of the shocks and let hang from bottom, raise the axle from the center with a piece of wood between it
once the springs are in place that is the place to adjust the shock length to. this will also keep the springs in place when u raise the rear of the car
something like that haha
Old Mar 15, 2013 | 01:10 PM
you need to adjust the shock length itself. everybody does it different but what i do is put the jack under the spring perch and jack the car up, support the frame with a jack stand, unbolt the rear shock, then fully droop the spring perch (undo jack). with that done you'll be able to see where the shock lines up to where it bolts on, when i did mine i had to shorten the shock up so that i had to jack the spring perch back up to be able to bolt it together (i don't remember the actual length i adjusted it to) but with that done the spring shouldn't want to "fall" out of the perch, the shock is holding everything up. so measure the length of the shock since it's now adjusted and do the same process on the opposite side to the exact same length.
with this done when you change the dampening it will have more of an effect and should "stiffen" up your ride
Old Mar 15, 2013 | 01:12 PM
thanks for the info will be doing this tomorrow
Old Mar 15, 2013 | 01:20 PM
go thing u didnt get ksport(me) there isnt a way to adjust the length and to adjust the damper you have to twist off the top of the shock
let us know how the adjustments go
Old Mar 15, 2013 | 02:28 PM
a buddy has ksports and if i follow him it's funny how much his car bounces around, especially in the rear that was 1 mistake ksport made, not having adjustable rear shocks
Old Mar 15, 2013 | 02:48 PM
yea for reals, im back on my stockers at the moment and i raised it an inch in the rear and it rides better but has some bounce still, some Swift springs are on the list
the 45 series is too tall for my lows tho haha
Old Mar 15, 2013 | 02:56 PM
in my case it i feel the front is the cause of my bounce but i can be wrong
Old Mar 15, 2013 | 08:51 PM
kzak104's Avatar
if you buy 800 dollar megan racing **** coilovers, ya, it will ride like ****. i have been in many many many cars that are on coilovers that ride better then my car did stock.
im on kw and the ride is a little rougher, but if you slam your car and have soft suspensions your going to be rubbing and bottoming out everywhere.
im sick of people slamming their car to the ground on coilovers and bitching about the rough ride....
Old Mar 15, 2013 | 09:03 PM
Fitz88's Avatar
That's why u slam it and suck it the **** up lol
Old Mar 15, 2013 | 09:18 PM
BoostedEco's Avatar
if you buy 800 dollar megan racing **** coilovers, ya, it will ride like ****. I have been in many many many cars that are on coilovers that ride better then my car did stock.
Im on kw and the ride is a little rougher, but if you slam your car and have soft suspensions your going to be rubbing and bottoming out everywhere.
Im sick of people slamming their car to the ground on coilovers and bitching about the rough ride....
+1
Old Mar 15, 2013 | 09:32 PM
turbosmart4's Avatar
7 inches
O wait
Old Mar 15, 2013 | 09:54 PM
Omiotek's Avatar
I don't consider the cobalt a good riding car... I've been in cars with motions, ohlins, ast, Andes and they all ride stiff...does that mean sitting ride? No...just means its stiffer and you will feel it
Old Mar 15, 2013 | 10:45 PM
my Megans ride fine, yea it can be a little rough at times (like expansion joints on these damn PA highways) but i don't see why everyone bashes the ride of them, and i've only ever adjusted the settings and pre-loads once too. they may not be quite the quality of KW's but they're just fine for me right now
Old Mar 15, 2013 | 10:53 PM
RandyO's Avatar
I have coilovers.......
Old Mar 15, 2013 | 11:02 PM
kzak104's Avatar
looking at ur sig it looks like u just took the springs out
Old Mar 15, 2013 | 11:17 PM
serega12's Avatar
springs AND struts/shocks.
Old Mar 16, 2013 | 01:46 AM
RandyO's Avatar
You know me all too well! That's exactly what I did!
Old Mar 16, 2013 | 11:15 AM
and your axles are made of pixie dust!
