How Much to Replace Steel Brake Line
Old Dec 7, 2009 | 11:58 AM
gpro's Avatar
This is just a general question regarding my '97 Explorer. Got an estimate of $900 to replace the steel brake lines that come from the engine compartment to the rear brakes. They are extremely rusted, and burst a little while ago.
Should this job cost $900??? And take the entire week?
To me it sound ridiculous, or I may just be paranoid because I have personal issues with this mechanic.
Old Dec 7, 2009 | 12:11 PM
phillips01's Avatar
its really a pain in the a== /it takes 1 to 1.5 days to do it .Done it lots of times . I usually charge 1000.00 but i replace all lines and do it right .if they are chargeing 900 for just 1 line its kinda high but ,until you done it you wont know how hard it can be
Old Dec 7, 2009 | 12:22 PM
Maven's Avatar
Typically a job like this is billed at whats called T&M, that is strictly time and materials. So brake pipe and some flare nuts are gonna run MAYBE, $50, AND IF LABOR IS $85/HR thats 10hrs of labor, seems a little bit high for just rear brake pipes, but not completely out of the ordinary or truly like thievery.
Old Dec 7, 2009 | 01:30 PM
qwikredline's Avatar
x 2 what maven says but if you buy from Ford the bundle of lines it could cost a lot. The brake line bundle for a J body cavvy are about 300 from the dealer and you gotta drop the rear of the cradle to stuff it in and its all rusty and stuff. Good luck....
Old Dec 7, 2009 | 02:57 PM
Wangspeed's Avatar
I feel your pain. Last winter, I was parallel parking my 97 Ram 2500, Cummins powered truck, and the pedal starting going to the floor. Took a look underneath and found that it had rusted through 2 hard lines (one going to the back).
I had 2 lines replaced, but not nearly as expensive as your quote. IIRC, it was like 400.
Warren
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
