Ingalls Camber Kit???
go to a good year tire. They have them. Mine had 6 in stock and they worked great.
not ingalls but you know what i mean
if you need one i can pick it up and ship it to you if you dont have one close
Last edited by BOOSSTED 06; Jul 27, 2007 at 05:48 PM. Reason: Automerged Doublepost
thanks man ill look into that...ive one accros the street. Im still looking for the Ingalls one jus tin case tho.
yea i do.... My tires are already wearing completely uneven. And Ive only had my new tires for about 3 weeks and i barely drive it
for 20 bucks its worth the expense
Last edited by 06CobaltSSS; Jul 27, 2007 at 05:53 PM. Reason: Automerged Doublepost
no matter how much you lower you car it doesmatter... it messes with the camber no matter how small and over the time the tires will show it. With sportlines the camber is adjusted about +-.87 degrees not sure if its positive or negative. The 20 dollar kit adjusts it up to 1 degree which is right where i need it.
If you dont think you need it dont buy it. I dont want to spend money on new tires when i dont need them.
I saw Ingalls camber kits in www.gravanatuning.com,
Oh yea, I was wondering if buying a camber kit, do you need to buy for front and back or just front??
you don't need a camber kit...never have had one on any car I've had lowered. Tires have been fine...I"ve talked to numerous shops and they all say waste of money for a daily driver...Only if you are auto X or stuff like that.
Quote: Originally Posted by SSKevinSCJust ordered Eibach Sportlines. Should I have gotten a Camber Kit Also If so can I Install this myself ?
No = not needed, and No cause you NEED an alignment check after. And I know many have posted, "oh I just did them and its fine." Well I'm a perfectionist and every time I adjust my suspensio or take apart anyhting on the suspesion I at least have it checked; so as not to wear out tires or bearings.
Quote: Originally Posted by gRuNg3b0yMight be a stupid question but do you need camber kits in the rear too?? I could only find front camber kits..
Solid axle doesnt need one, if it does its cause the rear axle is bent. (using shims to correct)
The only reason any cobalt needs a camber kit is if its been in an accident, or if youre like me and using it for racing and want a lot of neg camber on the front. Many threads on sportlines and ksports and others very low do not need camber bolts to be within alignment spec not to wear the tires.
Sep 28, 2015 12:51 PM
